Explode method in 2004
Hi all
I am working in 2000 and in my project am creating a block using the addblock method and later in certain situations i am exploding the block and changing its dimensions.This works fine in 2000.
The same code when i try in 2004 the exploded block object seems to be moved from the current position and the objects are placed at some othe location.What could be the problem.I had checked with ucs both are in wcs.
Sri
Do anyone faced such problems>
thanks
sri
That's odd that you have the problem w/ 2004 and not 2000. I'm exploding blocks in 2006 no problem whereas in 2000 I needed to use a transform before explode sub as a blockref with text in it wouldnt explode. I have noticed attributes seem to follow different rules in 3d, tied in w/ the insertion pt. Anyway the first thing to check is does the same problem occur w/ a blockref that is a circle w/ the insertion pt at center and a blockref with the insertion pt at 0,0,0. Now do this again with the blockrefs scaled to 2. It sounds like a scaling issue
Thanks Bryco for your valuable inputs
I am not using any text objects inside the block.the block consists of only a line or a polyline with 4 or 5 segments.
even in this case when i explode the block the entities inside the blocks gets moved. i am not scaling the blocks.
thanks
Sri
