Execution Error: "...."
I'm geting this error after I select a menu item for programming a drop down
item with this.
Command: (defun c:grdwiz()(vl-vbarun
"H:/JBIMENU/VBA/LDTVBA.dvb!JBIGradeModule.showform")) C:GRDWIZ
Command: grdwiz Execution
error"H:/JBIMENU/VBA/LDTVBA.dvb!JBIGradeModule.showform"
The routine seems to run, but I'm not sure why this is showing up. Any help
is appreciated....
TIA--
James Wedding
IT Manager
Jones & Boyd, Inc.
Dallas, TX
jwedding@*NOSPAM*jones-boyd.com
Check for, and eliminate any "End" statements in your VBA code. That's
usually the cause of the execution error.
Gary
Thanks...I'm using them at various points to bail out of the routine. Is
there a better way?
James Wedding
IT Manager
Jones & Boyd, Inc.
Dallas, TX
I believe the only other options are to "Hide" or "Unload" the form. Have
you proven that the "End" statement is causing the problem?
Gary
To be honest no. It's not really something I'm losing sleep over, just one
of those things that will freak out a user at some point, I'm sure....
James Wedding
IT Manager
Jones & Boyd, Inc.
Dallas, TX
Create an exit function and call it instead. Don't forget to do your clean
up!
"James Wedding" wrote in message
news:347214187BEFC7FF7D7039D6A9DBB916@in.WebX.maYIadrTaRb...
> James Wedding
> IT Manager
> Jones & Boyd, Inc.
> Dallas, TX
Bu I like being a lazy programmer. 🙂 All right, I'll clean up.....
James Wedding
IT Manager
Jones & Boyd, Inc.
Dallas, TX
