Executing VBA-routine from VB6
Hello
I am trying to run a VBA-routine in AutoCAD 2000, from VB6
The RunMacro command could be used, but the tricky part, is that I want VB6
to continue.
The RunMacro does not continue until the Macro has been finished.
AcadApp.RunMacro ("j:\cadserver\cadserver.dvb!OpenDwg.xxx")
Do
DoEvents
If Timer - AcadTime > ErrorWait# Then
ErrorMsg$ = "Error when running Macro-job in AutoCAD"
ErrorFlag% = 1
exit do
End If
Loop While Dir$(JobFile$) <> ""
Any suggestions to how I can trigger OpenDwg.xxx, and continue in VB6??
NOT 'sendcommand', because this requires an open drawing.
Kind regards
Michael Christoffersen
3DI
Why not just move the VBA code into your VB project? Then RunMacro won't be an
issue.
http://www.acadx.com
Win a free autographed copy of
"AutoCAD 2000 VBA Programmer's Reference"
"Michael Christoffersen" wrote in message
news:04D67591BCADFF89CA2971533B6C475C@in.WebX.maYIadrTaRb...
> Hello
> to continue.
> Do
> DoEvents
> ErrorFlag% = 1
> exit do
> End If
> Kind regards
> 3DI
I have thought about that solution. However another company makes the VBA
and I just need to activate it.
Michael
"Frank Oquendo" wrote in message
news:CEADE5BC4342BCEA8C5BA1CF3D29C9C1@in.WebX.maYIadrTaRb...
be an
> issue.
> > Hello
VB6
> > to continue.
> > Do
> > DoEvents
> > ErrorFlag% = 1
> > exit do
> > End If
> > Kind regards
> > 3DI
