Excelink.dvb
Excelink.dvb
Excelink.dvb
I am trying to use the Excelink.dvb located in C:\Program
Files\ACAD2000\SAMPLE\VBA and when I rotate a block in the drawing, it will
no longer import new information from excel. Is there anyone who knows of
this?
"Matt Starr" wrote in message
news:858E126CA646FCE2A2C16EAC52B86A3B@in.WebX.maYIadrTaRb...
will
> this?
Can I ask how you are using this file? If I try to use it, it looks for a
Bill of Materials worksheet which I don't have. I'm going through line by
line to modify the vba file now to get it to look for another file but just
wanted to see if I'm missing something glaringly obvious. Is this setup to
work with BOM only or is it able to be used for other worksheets? Is there
directions somewhere? Thanks!
-Kirsten
will
> this?
In the C:\Program Files\ACAD2000\SAMPLE\VBA directory there is a readme.txt
file that explains how run this demo. You must first open C:\Program
Files\ACAD2000\SAMPLE\ACTIVEX\ExtAttr\attrib.dwg which has a BOM with the
necessary attributes. Then load the Excelink.dvb project and run the macro
it installs.
--Mike McGuire
"Kirsten" wrote in message
news:B59EB5B7A8E02973FE3BE30B1FEA13F2@in.WebX.maYIadrTaRb...
just
to
there
> -Kirsten
> will
of
> > this?
