excel vba update title blocks in drawing with multiple layouts
Message 1 of 33
Hi I am looking for some help on how to update the title block in drawings with multiple layout tabs. So far my code will only update the title block in the active layout. I was looking into using acSelectionsetall but couldn't figure out how to apply it.
Sub ModifyFrameBlock(DWG As AcadDocument, QUANTITY As String)
Dim blk As AcadBlockReference
Dim attr As Variant
Set blk = FindFrameBlock(DWG)
If Not blk Is Nothing Then
For Each attr In blk.GetAttributes()
If attr.TagString = "RELEASE-NO" Then
attr.TextString = RelNo
DWG.SummaryInfo.SetCustomByKey "Frame No", lbFrameName ' drawing property field
DWG.SummaryInfo.SetCustomByKey "Frame Qty", QUANTITY ' drawing property field
If attr.TagString = "RELEASE-DATE" Then
attr.TextString = TBReleaseDate
Next
CreatePDF DWG
DWG.AuditInfo FixError ' audit and fix error in drawing
DWG.PurgeAll ' purge drawing
DWG.Close True
End Sub
Function FindFrameBlock(DWG As AcadDocument) As AcadBlockReference
Dim ent As AcadEntity
For Each ent In DWG.PaperSpace
If TypeOf ent Is AcadBlockReference Then
If ent.Name = "blockname" Then
Set FindFrameBlock = ent
Exit Function
Next
Set FindFrameBlock = Nothing
End Function
Replies (32)
Message 2 of 33
norman.yuan
Well, since you search the block in AcadDocument.PaperSpace, thus, you only search the active layout. Furthermore, the the active layout is ModelSpace, the code will not get anything back. There is 2 way to do:
1. Set each layout to active, then search the PaperSpace, as your code to. This would be slow, because AutoCAD has to change active layout, which, not to mention, may trigger "regen", making thing even slower;
2. You can simply loop through all layout and search AcadLayout.Block.
A slight logic optimization to your code is to let FindFrameBlock() method return an array of block references, rather than one, because it is possible you may have the same block on all paper layouts. So, here is the code to do it:
Option Explicit
Public Sub ModifyFrameBlocks()
    Dim blkName As String
    blkName = "TBox"
    Dim i As Integer
    Dim blks As Variant
    blks = FindBlocksOnAllLayouts(blkName)
    If VarType(blks) = vbEmpty Then
        MsgBox "No block """ & blkName & """ found in current drawing!"
    Else
        For i = 0 To UBound(blks)
            Set blk = blks(i)
            ''Update each block reference here
        Next
End Sub
Private Function FindBlocksOnAllLayouts(blkName As String) As Variant
    Dim blks() As AcadBlockReference
    Dim i As Integer
    Dim lay As AcadLayout
    For Each lay In ThisDrawing.Layouts
        ''You may or may not wna to exclude "Model" layout
        '' depending on your business requirements
        If UCase(lay.Name) <> "MODEL" Then
            For Each ent In lay.Block
                    Set blk = ent
                    If UCase(blk.Name) = UCase(blkName) Then
                        ReDim Preserve blks(i)
                        Set blks(i) = blk
                        i = i + 1
            Next
    Next
    FindBlocksOnAllLayouts = blks
End Function
Of cause, if you only need to find one block, then you can stop the searching loop once a block reference is found.
Another thing to optimize your code in method ModifyFrameBlock():
Since this method gets a AcadDocument passed in, you'd better not close the document inside this method. Rather, the document should be closed outside the method. Something like:
For Each dwgName in DwgNames
    ''Open the drawing
    Set dwg=AcadApp.Documents.Open(dwgName,...)
   '' Do the work
    Call ModifyFrameBlock(dwg, quantity)
    ''Close, save if necessary
    dwg.Close True
Next
HTH
Norman Yuan
Drive CAD With Code
Message 3 of 33
 I am pretty new to coding, your patient is appreciated. I copied your code and here is what I have but am unable to get it to work. Please let me know what I am missing. Thanks
Set DWG = AcadApplication.Documents.Open(Filename)
Call ModifyFrameBlocks(DWG, QntyNum)
dwg.Close True
Dim i As Integer
blkName = "11x17_Frame_TB-2015" 'block name
Dim blks As Variant
Else
Set blk = blks(i)
attr.TextString = "Release1"
attr.TextString = "yyyy/mm/dd"
Next
End Sub
Dim i As Integer
For Each lay In DWG.Layouts
For Each ent In lay.block
Set blk = ent
Set blks(i) = blk
i = i + 1
Next
Next
End Function
Message 4 of 33
what about AcSelectionSetAll? Instead of cycling through all the layouts use AcSelectionSetAll but I can not any sample codes for my condition. Appreciate your help.
Message 5 of 33
norman.yuan
When post your code, please use "insert code" button in the message window's toolbar, so that the code can be easier for viewing.
You also should indicate where line of code does not work (if you ever stepped through the code in debugging mode, especially when the code does not work).
Anyway, it is here in your code that is wrong:
  Set blk = blks(i)
Next
If should be:
  Set blk = blks(i)
  attrs=blk.GetAttributes()
  For Each attr in attrs
  Next
Next
Norman Yuan
Drive CAD With Code
Message 6 of 33
norman.yuan
Yes, you can create a selectionset with or without filter to locate the target block references. In general, it does not make much/noticeable difference in term of speed of finding the blocks. in comparison to the way of looping through AcadLayout.Block.
Norman Yuan
Drive CAD With Code
Message 7 of 33
I am getting a ByRef argument type mismatch for (blkName). What am I doing wrong now. Also, is it correct to pass DWG to the
ModifyFrameBlock and FindBlocksOnAllLayouts?
Dim DWG As AcadDocument
Dim releaseFile As String
Set DWG = ACAD.Documents.Open(releaseFile) ModifyFrameBlock DWG Public Sub ModifyFrameBlock(DWG As AcadDocument) Dim blkName As String blkName = "11x17_Frame_TB-2015" Dim i As Integer Dim blk As AcadBlockReference Dim blks As Variant blks = FindBlocksOnAllLayouts(blkName) 'I am getting a ByRef argument type mismatch for (blkName) If VarType(blks) = vbEmpty Then MsgBox "No block """ & blkName & """ found in current drawing!" Else For i = 0 To UBound(blks) Set blk = blks(i) attrs = blk.GetAttributes() For Each attr In attrs If attr.TagString = "RELEASE-NO" Then attr.TextString = "Release1" End If If attr.TagString = "RELEASE-DATE" Then attr.TextString = "yyyy/mm/dd" End If Next Next End If End Sub Private Function FindBlocksOnAllLayouts(DWG As AcadDocument, blkName As String) Dim blks() As AcadBlockReference Dim i As Integer Dim ent As AcadEntity Dim blk As AcadBlockReference Dim lay As AcadLayout For Each lay In DWG.Layouts If UCase(lay.Name) <> "MODEL" Then For Each ent In lay.block If TypeOf ent Is AcadBlockReference Then Set blk = ent If UCase(blk.Name) = UCase(blkName) Then ReDim Preserve blks(i) Set blks(i) = blk i = i + 1 End If End If Next End If Next FindBlocksOnAllLayouts = blks End Function
Message 8 of 33
norman.yuan
Set DWG = ACAD.Documents.Open(releaseFile) ModifyFrameBlock DWG Public Sub ModifyFrameBlock(DWG As AcadDocument) Dim blkName As String blkName = "11x17_Frame_TB-2015" Dim i As Integer Dim blk As AcadBlockReference Dim blks As Variant blks = FindBlocksOnAllLayouts(blkName) 'I am getting a ByRef argument type mismatch for (blkName) If VarType(blks) = vbEmpty Then .... End If End Sub Private Function FindBlocksOnAllLayouts(DWG As AcadDocument, blkName As String) .... End Function
Well, I guess you maybe worked "too hard" to see the obvious. Take some time off in the weekend :-(.
The function FindBlocksOnAllLayouts() has 2 argument, but your code only supplys one. That line of code should be:
blks = FindBlocksOnAllLayouts(DWG, blkName)
Norman Yuan
Drive CAD With Code
Message 9 of 33
as per your function signature:
you must call it by supplying both "AcadDocument" and "String" type arguments:
furthermore I'd suggest you to
- use Option Explicit at the very top of each module.
  this will force you to explicitly declare all used variables, instead of assuming undeclared ones as of "Variant" type", but this effort will give you much more control over your code
 so you may want to add/revise the following:
Dim blks() As AcadBlockReference '<<< declare it as of the proper type
Dim attrs As Variant '<<< declare it!
Dim attr As AcadAttribute '<<< declare it!
- in FindBlocksOnAllLayouts(), add a check on found block having attributes:
                        If blk.HasAttributes Then '<<< check if block has attributes before adding it to the array
                            Set blks(i) = blk
                            i = i + 1
  so as to fill blks() with relevant block references only
- add some exception handling in case no block is found
Finally you could consider the following alternative "SelectionSet" approach:
    Dim i As Integer
    Dim blcksObj As AcadSelectionSet
    Set blcksObj = FindBlocksOnAllLayouts2(DWG, blkName) '<<< collect all blocks with given name in a selectionset
    If blcksObj.Count > 0 Then ' if any block found
        ReDim Preserve blks(0 To blcksObj.Count)
        For Each blk In blcksObj
                Set blks(i) = blk
                i = i + 1
        Next
        If i = 0 Then
            MsgBox "No blocks """ & blkName & """ with attributes found in current drawing!"
        Else
            ReDim Preserve blks(0 To i - 1)
                Set blk = blks(i)
                    ElseIf attr.TagString = "RELEASE-DATE" Then
                Next
            Next
    Else
        msgBox "No blocks """ & blkName & """ found in current drawing!"
End Sub
Function FindBlocksOnAllLayouts2(DWG As AcadDocument, blkName As String) As AcadSelectionSet
    Set FindBlocksOnAllLayouts2 = CreateSelectionSet(DWG, "blcks")
    Dim gpCode(0 To 1) As Integer
    Dim dataValue(0 To 1) As Variant
    gpCode(0) = 0:    dataValue(0) = "INSERT"
    gpCode(1) = 2:    dataValue(1) = blkName
    FindBlocksOnAllLayouts2.Select acSelectionSetAll, , , gpCode, dataValue
End Function
Function CreateSelectionSet(acDoc As AcadDocument, SSset As String) As AcadSelectionSet
    On Error Resume Next
    Set CreateSelectionSet = acDoc.SelectionSets(SSset)
    If Err Then Set CreateSelectionSet = acDoc.SelectionSets.Add(SSset)
    CreateSelectionSet.Clear
End Function
Message 10 of 33
robert.kulas
I would like to implement this code to my excel application, but the compiler sends me error info: "Object required" and marked the line (please see picture below)
Could you help me find what is the issue?
I would appreciate for help.
Message 11 of 33
Ed__Jobe
It looks like the variable "attr" is not dimensioned anywhere.
Ed
How to post your code.
Message 12 of 33
norman.yuan
AcadBlockReference returns  a Variant, which is an array of AcadAttributeReference object. In VBA, For Each... Next does not apply to array, thus your code error out at:
Next
the code should be
Dim i as Integer
For i=0 to UBound(attrs)
  attr=attrs(i)
  If attr.TagString = "xxxx" Then
Next
Norman Yuan
Drive CAD With Code
Message 13 of 33
robert.kulas
Unfortunately, this changes did not solve the problem. Below is the full code from the post with minor changes.
Sub ModifyFrameBlock()
Dim AutoCadApp As Object
blkName = "DwgTable01"
Dim i As Integer
Set AutoCadApp = GetObject(, "AutoCAD.Application")
Set DWG = AutoCadApp.ActiveDocument
Set blks(i) = blk
i = i + 1
Next
If i = 0 Then
Else
Set blk = blks(i)
If attr.TagString = "REVISION" Then
attr.TextString = "Rev 1"
ElseIf attr.TagString = "SHEET" Then
attr.TextString = "1/100"
Next
Next
Else
MsgBox "No blocks """ & blkName & """ found in current drawing!"
End Sub
Message 14 of 33
norman.yuan
Firstly, please use the "</>" button of the toolbar above the message window to post code, which preserves the code format so that the code is easy to read.
Your previous code did not indicates how the variable is declared. Now, seeing the whole section of the code, here is at least 3 eerrors:
1. as I previously replied, you cannot use For Each... against an array
Next
Has to be
Next
2. the variable "attr" is declared wrong: it should be AcadAttributeReference, not AcadAttribute
3. Since "attr" is an Object, you need to use "Set" to assign value to it
For i=....
  Set attr=attrs(i)
Next
Norman Yuan
Drive CAD With Code
Message 15 of 33
robert.kulas
thank you for the answer. I do not know what is wrong (maybe my fault). I changed acc. to your message but it does not work...
Could you write some code?
I would appreciate for it.
Message 16 of 33
robert.kulas
Super, thank you again. I have found the issue. I had to add additional control variable (j)...
Message 17 of 33
norman.yuan
I'd strongly suggest you do wrap your code into smaller chunk, which not only makes the code much easier to follow/read/understand, but also naturally prevents the bug (of unknowingly used a variable with undesired initial value). Something like:
Private Sub SetAttributesInBlocks(blks As Variant)
  Dim i As Integer
   SetAttributes blk
  Next
End Sub
Private Sub SetAttributes(blk As AcadBlockReference)
  Dim i As Integer
  Dim attr As AcadAttributeReference
  If Not blk.HasAttributes Then Exit Sub
  For i = 0 To UBound(attrs)
    Set attr=attrs(i)
    Select Case UCase(attr.TagString)
      Case "REVISION"
        attr.TextString="xxxxx"
      Case "SHEET"
        attr.TextString="yyyyy"
    End Select
  Next
End Sub
Norman Yuan
Drive CAD With Code
Message 18 of 33
Ed__Jobe
@robert.kulas
In addition, I would also suggest that you set your VBA Options to require variable declaration. This automatically inserts "Option Explicit" in the Declarations section of any new module you create. This will cause the IDE to notify you if you try to use a variable that hasn't been dimensioned. For existing modules, you will have to manually add the line to the top  of your modules.
Ed
Message 19 of 33
robert.kulas
Thank you for all your support.
Message 20 of 33
Ed__Jobe
If your problem is solved, please mark mark the posts accepted as solution.
Ed
