EXCEL 2010 VBA AUTOCAD
I am in Excel 2010 VBA editor.
I am trying the simple code below (Autocad IS running, I am just trying to access it in order to build some objects)
Public Sub GETACAD()
Dim acadApp As AcadApplication
Set acadApp = GetObject(, "AutoCAD.Application")
End Sub
It gives me the following error message:
user-defined type not defined.
Any problems with the new EXCEL 2010?
What am I missing?
Please advise
Thank you
Tuli
Hallex
Try change on:
Set acadApp = GetObject(, "AutoCAD.Application18.1")
or whatever you have a current acad release
to get it type in the autocad command line
ACADVER  then press Enter
It will be return something like:
ACADVER = "18.0s (LMS Tech)" (read only)
grab just numeric only value from there and
build your string after:
Set acadApp = GetObject(, "AutoCAD.Application18.0") or 18.1 or 18.2 , ETC
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thnaks
I did that and stiill have the same problem.
I should have mentioned that earlier: I get the error on the line
<<Dim acadApp As AcadApplication>>
truss_85
Try that it is works fine.
On Error Resume Next
Dim acadapp As AcadApplication
Set acadapp = GetObject(, "autocad.application")
If Err Then
    Err.Clear
    Set acadapp = CreateObject("autocad.application")
        If Err Then
            MsgBox Err.Description
            Exit Sub
        End If
End If
End Sub
Hallex
Would not you forget to add references to AutoCAD 2010 Library?
Tools->References->AutoCAD 2010 Library
and also for your code logic AutoCad must be open before
once more
Try late binding? declare as Object:
Dim acadApp As Object
Hallex
Try another way
Option Explicit
            Public Sub TryOpenAcad()
            Dim acadApp As AutoCAD.AcadApplication '<-- full path
            Dim acadDoc As AutoCAD.AcadDocument '<-- full path
            Dim fileName As String
            fileName = "C:\Test\WorkingDrawing.dwg" '<-- change a drawing name here
            Set acadApp = New AutoCAD.AcadApplication
            acadApp.Visible = True
            AppActivate acadApp.Caption, True
            Set acadDoc = acadApp.Documents.Open(fileName)
            acadDoc.Activate
            acadApp.WindowState = acMax
            acadApp.Eval "msgbox(""Welcome to AutoCAD window"")"
            acadDoc.Close False, fileName '<-- close without saving
            acadApp.Quit
            Set acadDoc = Nothing
            Set acadApp = Nothing
            End Sub
Tested on Excel 2007 / Acad 2009 though
