Events and Plotting
Events and Plotting
Message 1 of 1
Events and Plotting
I need to interrupt Acad's plotting/publishing of multiple layouts to insert an object in PS prior to plotting. My code, Using Events, ie. beginPlot and/or LayoutSwitched, all works well on single layout instances or when the user selects the layout manually, plotting one layout at a time.. If multiple layouts are selected, the code is ignored. This idea also needs to be applied to plotting/publishing with the sheet set manager. I can't find a way to "catch" the autocad plot/publish process as each draswing or layout is being accessed. The code must be transparent to the user, hence the events approach. Any ideas where to go to find a direction? Thanks ahead of time. Jim jsimondallas@earthlink.net
Replies (0)
