Error setting mspace
Greetings!
I have some viewports in the paperspace I want to access. When i declare mspace = true, it says that you have no active modelspace viewports and switching to paper space. I already set the display of the paperspace viewport to true and have set the active space to paperspace so I dont know why it is giving this error. Using AutoCad 2007.
If the help doesn't apply:
NOTE Before using the MSpace property, the ActiveSpace property must be set to acPaperSpace, and the display control of the PViewport object must be switched on by the Display property.
Then show us a bit of code
