Error adding object to symbol table.
the following line of code produces the following error:
"Error adding object to symbol table."
vector(1) = returnPnt(1) + ThisDrawing.ActiveUCS.YVector(1)
It doesn't produce this error immediately, only after the following cope has
been run a number of times.
full code:
Public Sub construction_line_VER_sub()
'Author: Tom Burton
'Date: 11/6/00
'Procedure Purpose: create vertical construction line
'Revs:
'RevId Date Author
' Description
'On Error GoTo errorcheck
Dim a, CONSTRUCTIOnEXISTS As Integer
Dim returnPnt As Variant
Dim xlineObj As AcadXline
Dim vector(0 To 2) As Double
' Return a point using a prompt
returnPnt = ThisDrawing.Utility.GetPoint(, "Enter a point: ")
If IsEmpty(returnPnt) Then GoTo ender
returnPnt(2) = 0
vector(1) = returnPnt(1) + 1
vector(0) = returnPnt(0)
vector(2) = 0
vector(0) = returnPnt(0) + ThisDrawing.ActiveUCS.YVector(0)
For a = 0 To ThisDrawing.Layers.Count - 1
If ThisDrawing.Layers(a).Name = "CONSTRUCTION" Then
CONSTRUCTIOnEXISTS = True
End If
Next
If CONSTRUCTIOnEXISTS <> True Then
ThisDrawing.Layers.Add ("CONSTRUCTION")
ThisDrawing.Layers("CONSTRUCTION").COLOR = 11
End If
If ThisDrawing.ActiveLayout.Name = "Model" Then
Set xlineObj = ThisDrawing.ModelSpace.AddXline(returnPnt, vector)
Else
Set xlineObj = ThisDrawing.PaperSpace.AddXline(returnPnt, vector)
End If
If ConLine_Color = 0 Then
ConLine_Color = 101
Else
ConLine_Color = ConLine_Color + 5
End If
If ConLine_Color >= 200 Then ConLine_Color = 100
xlineObj.COLOR = ConLine_Color
xlineObj.Layer = "CONSTRUCTION"
ender:
Exit Sub
errorcheck:
If Err <> -2147352567 Then
MsgBox (Error(Err))
Else
Resume Next
End If
End Sub
Some of the drawing file will cause an error "Error adding object to symbol
table" when the following line is executed.
TransMatrix = ThisDrawing.ActiveUCS.GetUCSMatrix()
The drawing file has no problem at all. Can someone please tell me how to
fix this kinds of error or get the ucs matrix without hitting on this error?
Sunny
Sunny
