Error 91 While Adding A Table
samialtas
samialtas
I gave a try to this code found on https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-ActiveX/files...
Sub Example_AddTable()
    ' This example adds a table in model space
    Dim MyModelSpace As AcadModelSpace
    Set MyModelSpace = ThisDrawing.ModelSpace
    Dim pt(2) As Double
    Dim MyTable As AcadTable
    Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
    ZoomExtents
End Sub
And when I run it, it throws Error 91. I declared pt coordinates which means evertyhing seems OK in order for the code to work.
Please help.
norman.yuan
The error is because you DID NOT supply an valid point coordinate in the form of Double array. That is, the code declares an variable pt as an array of Double, but does not fill the 3 elements of the array with values, thus, pt is an EMPTY array.
To correct your code, you need to specify a valid point coordinate:
Dim pt(2) As Double
pt(0) = 0.0 : pt(1) = 0.0 : pt(2) = 0.0  '' assume you insert the table at (0, 0, 0)
Norman Yuan
Drive CAD With Code
