EndCommand
EndCommand
Message 1 of 13
EndCommand
Hello everyone,
I'm almost done with the little program I'm writing. I've just run into a
small snag. Here's the situation: I want a macro to run each time a
drawing is opened. I've discovered the EndCommand routine and I can get it
to run great. The problem is, it was running even if the open command was
cancelled. I thought I had this figured out by using the BeginCommand event
to capture the drawing name and then comparing it it with the EndCommand to
see if a new drawing was actually opened. Worked great except if I reopen
the drawing I'm currently in. Does anyone know of a way to determine if the
open command actually opened a drawing or if the command was cancelled.
Brian
Replies (12)
Message 2 of 13
Use the BeginOpen and EndOpen events of the application object.
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
"Brian Hailey" wrote in message
news:E35306A0618FB39B6984F2DCD9FD2E29@in.WebX.maYIadrTaRb...
> Hello everyone,
it
event
to
the
> Thanks,
> Brian
Message 3 of 13
Thanks for the response, Jorge. I was under the impression that those
events, being an application level event, only fire when the application is
opened. Please correct me if I'm wrong.
Brian
"Jorge Jimenez" wrote in message
news:2A2207964B0FAA16F9A758F679FEF628@in.WebX.maYIadrTaRb...
> > Hello everyone,
a
> it
was
> event
> to
reopen
> the
> > Thanks,
> > Brian
Message 4 of 13
The application object events "BeginOpen" and "EndOpen" will fire when you
open a document (drawing)
As a matter of fact, the argument for these two events is the "filename"
(dwg name) being openned.
news:47A87F27AA398913C3A732245C237EAF@in.WebX.maYIadrTaRb...
is
> Brian
> > > Hello everyone,
into
> a
get
> > it
> was
> > event
EndCommand
> > to
> reopen
if
> > the
cancelled.
> > > Thanks,
> > > Brian
Message 5 of 13
Thanks Jorge. I can't seem to get any of the application level events to
work on my computer though. I copy the example from the help file into a
class module, open a new drawing, and nothing. Do you know if I need to do
something different since I'm using LDD 2i? Or am I missing something else
completely?
Brian
news:1BEB20D46DAF492B368D6106EDD9C08C@in.WebX.maYIadrTaRb...
> is
> > Brian
message
> > > > Hello everyone,
> into
> > a
a
> get
> > > it
command
> > was
BeginCommand
> > > event
> EndCommand
> > > to
> > reopen
determine
> if
> > > the
> cancelled.
> > > > Thanks,
> > > > Brian
Message 6 of 13
if you're using VBA
first
dim withevents MiApp as AcadApplication
then
set MiApp = thisdrawing.application
news:EAA2DE989CF278D3CFAF0FF1B9C3ADAE@in.WebX.maYIadrTaRb...
do
else
> completely?
> Brian
you
"filename"
application
> > is
> > > Brian
> message
> > > > > Hello everyone,
run
> > into
> > > a
time
> a
can
> > get
> > > > it
> command
> > > was
> BeginCommand
> > > > event
> > EndCommand
> > > > to
I
> > > reopen
> determine
> > if
> > > > the
> > cancelled.
> > > > > Thanks,
> > > > > Brian
Message 7 of 13
Here is exactly what I have in a class module (copied directly from the help
files):
Public WithEvents ACADApp As AcadApplication ' Use with Application Event
Examples
Sub Example_AcadApplication_Events()
' This example intializes the public variable (ACADApp) which will be
used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept an generic
object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will first need to run this procedure.
' We could get the application from the ThisDocument object, but that
would
' require having a drawing open, so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application")
End Sub
Private Sub ACADApp_EndOpen(ByVal FileName As String)
' This example intercepts an Application EndOpen event.
' This event is triggered when AutoCAD finishes opening a drawing.
' To trigger this example event:
' 1) Make sure to run the example that initializes
' the public variable (named ACADApp) linked to this event.
' 2) Use AutoCAD to open an existing drawing and wait until the
' operation finishes
' Use the "FileName" variable to determine which drawing file is being
opened
MsgBox "A drawing was just loaded from: " & FileName
End Sub
What am I missing? Should this be placed in a different module? Do I need
to do something else to activate it? Do I need to load any specific
references?
Brian
Message 8 of 13
Try
Set ACADApp = ThisDrawing.Application
instead of
news:401C5A9F973AF5EF19FA1AC6A3EEE947@in.WebX.maYIadrTaRb...
help
> files):
Event
> Examples
> used
generic
> object
events,
> would
> End Sub
> opened
> End Sub
need
> references?
> Brian
Message 9 of 13
That didn't seem to help. In the help files under "Enabling Application
Level Events" is the following section:
To connect the declared object to the Application object:
1.. In the Code window for your main module, add the following line to the
declarations section:
Dim X As New EventClassModule2.. In the same window, add the following
subroutine:
Sub InitializeEvents() Set X.App = ThisDrawing.ApplicationEnd Sub3.. In
the code for your main module, add a call to the InitializeEvents
subroutine:
Call InitializeEventsOnce the InitializeEvents procedure has been run, the
App object in the class module points to the Application object specified,
and any event procedures in the class module will run when the events occur.
What does it mean by 3. "In the code for your main module, add a call to the
InitializeEvents subroutine:"? What main module? The only module I have is
the class module. Do I need more code outside the class module? Does this
only work if VBA calls the open command? I've tried this on several
computers in the office (both with LDD and vanilla) and I can't get it to
work.
Again, thanks for all the help, Jorge.
Brian
news:F83DC74F92128D36B238F329434550BA@in.WebX.maYIadrTaRb...
> Try
> instead of
> help
> > files):
> Event
> > Examples
be
> > used
> generic
> > object
> events,
that
> > would
> > End Sub
being
> > opened
> > End Sub
> need
> > references?
> > Brian
Message 10 of 13
Hi Brian.
Well, now you have your class defined but it won´t run by itself.
You need to have a main module wich will call the InitializeEvents sub
For a quick test, dol the dim the X object and Call the initializeevents
inside of the "thisdrawing" module.
So it should initialize once you start a new drawing.
news:5D5041B2EAED33C4BFD23D683B5BCF85@in.WebX.maYIadrTaRb...
the
> subroutine:
> subroutine:
occur.
the
is
this
> work.
> Brian
> > Try
> > instead of
the
> > help
> > > files):
> > Event
> > > Examples
> be
> > > used
> > generic
> > > object
> > events,
> that
> > > would
> > > End Sub
the
> being
> > > opened
> > > End Sub
> > need
> > > references?
> > > Brian
Message 11 of 13
WHOOHOOO!!!! It works now!!!!
If you are ever in Northern Colorado, let me know and I'll buy you a beer!
Heck, I'll buy you a whole case!
Cheers,
Brian
news:BAB278B38FC37EF367420722CEB26A64@in.WebX.maYIadrTaRb...
> Hi Brian.
Message 12 of 13
Ok, I have one more question (for now) Jorge.
I placed the Call InitializeEvents directly in the ThisDrawing module
without success but when I put it in a sub like this:
Private Sub AcadDocument_Activate()
End Sub
It did work, but not every time. Is there a better place to put this call
so it will work even on the very first drawing?
Brian
> Hi Brian.
> the
> > subroutine:
In
> > subroutine:
the
specified,
> occur.
> the
have
> is
> this
to
> > work.
> > Brian
message
> > > Try
> > > instead of
> the
> > > help
> > > > files):
Application
> > > Event
> > > > Examples
will
> > be
> > > > used
> > > generic
> > > > object
> > > events,
> > that
> > > > would
> > > > End Sub
drawing.
> the
> > being
> > > > opened
> > > > End Sub
I
> > > need
> > > > references?
> > > > Brian
Message 13 of 13
Thanks for the beer.
Now this is the tricky part.
Remember the VBA example calling for
a) Set ACADApp = GetObject(, "AutoCAD.Application")
and I told you to change it to
b) Set ACADApp = ThisDrawing.Application
Well, that was just for a quick test. The reason for whats happening is that
if you use a) the ACADApp will be set to the application object regardless
of the drawing (could be no drawing open at all)
if you use b) the ACADApp will depend on a current drawing being there.
So, you'll have to work this one out a little bit more.
I don´t use VBA for this sort of thing, I code in VB and create a DLL, but
that's another story.
news:16F773F21742ABF859358A11F340350F@in.WebX.maYIadrTaRb...
> End Sub
> Thanks,
> Brian
> > Hi Brian.
Application
to
> > the
> > > subroutine:
Sub3..
> In
> > > subroutine:
> the
> specified,
> > occur.
to
> > the
> have
> > is
> > this
> to
> > > work.
> > > Brian
> message
> > > > Try
> > > > instead of
from
> > the
> > > > help
> > > > > files):
> Application
> > > > Event
> > > > > Examples
> will
> > > be
> > > > > used
an
> > > > generic
> > > > > object
AcadApplication
> > > > events,
but
> > > that
> > > > > would
system.
> > > > > End Sub
> drawing.
event.
until
> > the
is
> > > being
> > > > > opened
> > > > > End Sub
Do
> I
> > > > need
specific
> > > > > references?
> > > > > Brian
