Delete a file using VBA
Hello everyone,
Does anybody have an example of how to delete a file (in this case a text file). I have looked at the help, and can see the object.delete and object.deletefile methods but neither have an example for me to rip-off err! I mean to draw inspiration from!
Roy Meaden.
Hi Roy,
Use the "Kill" statement.
From help ...
' Assume TESTFILE is a file containing some data.
Kill "TestFile" ' Delete file.
' In Microsoft Windows:
' Delete all *.TXT files in current directory.
Kill "*.TXT"
Delete Method
Description
Deletes a specified file or folder.
Syntax
object.Delete force
The Delete method syntax has these parts:
Part Description
object Required. Always the name of a File or Folder object.
force Optional. Boolean value that is True if files or folders with the read-only attribute set are to be deleted; False (default) if they are not.
Thanks for the reply, but call me Mr.Thickie, I do not know how to reference the file. I guess it would go something like (in pseudocode)
Dim filename as ?????
set filename = ??????
filename.delete true
set filename = nothing
Any help filling the blanks would be greatly appreciated!
Roy
dim strg as string
dim fs as variant
Set fs = CreateObject("scripting.filesystemobject")
strg = "myfile.txt"
ChDir {where myfile is}
fs.deletefile strg1, 1
I believe the current directory must be set to the file location for
this to work.
I always use something like Kill "myfile.txt"
Tom
> Roy
Thanks Tom ( And Gary )
Kill worked great. Another lesson learned.
Roy
