editing attriobutes from a block within a block
I have a block on my drawing called WT_INFO. within that block there is another block "sdwot" . Is there any way to get the attributes of sdwot without explding the WT_INFO block first? thanks in advance
arcticad
The most you could do is get the blocks definition and get the tag and default values.
I've had to explode the block to dig down into the block further.
insert sudo code here:
explode block
get attributes of exploded blocks
check if on locked layer
if so unlock layer
delete exploded contents
lock layer
(defun botsbuildbots() (botsbuildbots))
Yes. Since you have a nested block, the top-level block insertion (WT_INFO)
doesn't really matter. You need to go look at the WT_INFO *block* object,
not the block *reference* object.
R. Robert Bell
wrote in message news:5320009@discussion.autodesk.com...
