edit hatch and selectionsets
I have several hatch objects in a modelspace.
I want to edit those hatches by vba. I prefer without selection by the user.
(All hatches must be separated  I learned this must be done with sendcommand see my other topic).
I searched the helpfile and found acadselectionset. I don't know this is the right way and how I use this with the sendcommand method. Important I want vba to select the hatch.
I hope you understand what I mean
please you can help me?
gr. Laszlo
truss_85
There is no need to use sendcommand here is the code you needed.
Public Sub hatch_sel()
Dim oHatch As AcadHatch
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
On Error Resume Next
ThisDrawing.SelectionSets.Item("SS1").Delete
Dim ssetObj As AcadSelectionSet
Set ssetObj = ThisDrawing.SelectionSets.Add("SS1")
FilterType(0) = 0
FilterData(0) = "HATCH"
ssetObj.Select acSelectionSetAll, , , FilterType, FilterData
n = 0
For Each Item In ssetObj
    Set oHatch = ssetObj.Item(n)
    'do what you want to do
    n = n + 1
Next Item
End Sub
Thank you!
Now I understand filter in selectionset.
The sendcommand method I need to seperate already drawed hatches in the drawing.
gr. Laszlo
truss_85
Glad to help.
