Edit Attributes in a block
ladimirabdala
ladimirabdala
Some users help me to get an spefic block, now I'm trying get the attributes.
Set oLayout = ThisDrawing.ActiveLayout
Set oblock = oLayout.Block
For Each oEnt In oblock
If TypeOf oEnt Is AcadBlockReference Then
If oEnt.Name = "myspecificBlock" Then
msgbox "at this point I get the block as I want."
msgbox "How get the attributes this block?"
End If
End If
Next
How get and edit the attributes this block?
Sorry, must be a simple code, but my experience is in Lisp.
All help will be welcome.
Ladimir Abdala
CAD Systems Analyst
look up GetAttributes and HasAttributes in the help files
also do a google search on this ng
you'll get lots of samples
hth
mark
wrote in message news:5782554@discussion.autodesk.com...
attributes.
End If
End If
Next
Ladimir Abdala
CAD Systems Analyst
ladimirabdala
Thank you.
I found this code that function very well.
And I want share with others:
Option Explicit
Sub chngAtt()
Dim objEnt As ACADObject
Dim objRef As AcadBlockReference
Dim varAtts As Variant
Dim objAtt As AcadAttributeReference
Dim emptyPt As Variant''
ThisDrawing.Utility.GetEntity objEnt, emptyPt, "Select block...: "
If objEnt.ObjectName = "AcDbBlockReference" Then
Set objRef = objEnt
If objRef.HasAttributes Then
varAtts = objRef.GetAttributes
Set objAtt = varAtts(0)
objAtt.TextString = "CHANGED THIS TEXT"
End If
End If
End Sub
Ladimir Abdala
CAD Systems Analyst
fwiw, from what the experts say...
is slightly better written as;
If TypeOf objEnt Is AcadBlockReference Then
wrote in message news:5783418@discussion.autodesk.com...
Thank you.
Option Explicit
Sub chngAtt()
Set objRef = objEnt
End If
End If
End Sub
Ladimir Abdala
CAD Systems Analyst
