Early/late binding error VBA
gifari.zulk
gifari.zulk
Hi, all. I have problem in object binding with AutoCAD using VBA. I have below early binding code which works for most computers in my office:
Sub EarlyBindingCAD()
Dim AcadApp As AcadApplication
Dim AcadDoc As AcadDocument
Set AcadApp = GetObject(, "AutoCAD.Application")
Set AcadDoc = AcadApp.ActiveDocument
'Select objects in targeted layers
SSName = [{"COLUMN","BEAM","WALL","FLOOR"}]
For i = 1 To 4
AcadDoc.SelectionSets.Item(SSName(i)).Delete
AcadDoc.SelectionSets.Add SSName(i)
FilterType(0) = 8
FilterData(0) = SSName(i)
AcadDoc.SelectionSets.Item(SSName(i)).Select acSelectionSetAll, , , FilterType, FilterData
Next i
End Sub
 But few computers give compile error on first line (AcadApplication). The reference is not missing and correct (AutoCAD 2019 Type Library), the autocad variable types are even shown when typing the code. The excel's macro setting also seems correct, macros are enabled and Trust access to VBA project object model is checked.
So I tried modify the code into late binding below:
Sub LateBindingCAD()
Dim AcadApp As Object
Dim AcadDoc As Object
SSName = Array("COLUMN","BEAM","WALL","FLOOR")
For i = 0 To 3
FilterType(0) = 8
Next i
End Sub
Now it can connect/bind the AutoCAD object, but still gives compile error in last line (select all). This is because the acSelectionSetAll is enumeration that still needs to refer to AutoCAD reference before running. I tried replace this enumerate with integer, for example 4, but not working (does not select all in filtered layer).
Anyone have suggestion?
Thank you in advance.
Norman_Yuan
Integer value for acSelectionSetAll is 5, not 4 (acSelectionSetLast). Have you tried 5?
Norman Yuan
Drive CAD With Code
gifari.zulk
Oh yeah it is actually 5. Thank you.
Where can I see the list of numeric value of all enumeration for my other commands?
Norman_Yuan
In VBA IDE, open Object Browser, find acSelection enum and select/highlight the enum, at the botton of the Object Browser, you should see its value.
Norman Yuan
Drive CAD With Code
gifari.zulk
Great! Thank you again
