Dynamic blocks with VB
farzanjazil
farzanjazil
Hi everyone,
Is it possible to get all attributes from de Dynamic block and menwhile counting the block and put the information in Excel with VB ?
thanks alot
miguelmachadoecosta
Yes, it is possible. Here is an example:
Sub PutAttributesInExcel()
    Dim oApp_Excel As Excel.Application
    Dim oBook As Excel.workbook
    Set oApp_Excel = CreateObject("EXCEL.APPLICATION")
    Set oBook = oApp_Excel.workbooks.Add
    AppActivate ThisDrawing.Application.Caption
    Dim ssetObj As AcadSelectionSet
    'Select blocks onscreen
    Set ssetObj = ThisDrawing.SelectionSets.Add("seleccaoTemp")
    ssetObj.SelectOnScreen
    Dim blockRefObj As AcadBlockReference
    Dim varAttributes As Variant
    Dim cnt As Integer, j As Integer, k As Integer
    cnt = 0
    If ssetObj.Count = 0 Then
        MsgBox "No objects selected."
    Else
        For j = 0 To ssetObj.Count - 1
            If ssetObj.Item(j).ObjectName = "AcDbBlockReference" Then
                Set blockRefObj = ssetObj.Item(j)
                varAttributes = blockRefObj.GetAttributes
                ' Put attributes in Excel
                For k = LBound(varAttributes) To UBound(varAttributes)
                    oBook.Worksheets(1).Cells(k + 1, j + 1).Value = varAttributes(k).TextString
                Next k
                cnt = cnt + 1
        Next j
        If cnt = 0 Then
            MsgBox "No blocks selected."
        Else
            MsgBox "The number of blocks is " & cnt
    ssetObj.Delete
    oBook.SaveAs ("C:\temp\myfile.xlsx")
    oBook.Close
    oApp_Excel.Quit
    Set oBook = Nothing
End Sub
Don't forget to add the Excel Object Library in the References.
farzanjazil
thank u very much Miguel Costa
