dvb autorun issue
dvb autorun issue
dvb autorun issue
I have an issue; I need to autorun a dvd as soon as a drawing is opened. I used acad.dvb (and acad.lsp) but it works only when I fire up the application(if autocad is running and I try to open another drawing acad.dvb is not working anymore). I tried to use "document-activate" and call the procedure from acad.dvd but in my procedure i have to send a command like "thisdrawing.sendcommand..." and autocad crashes and I get "Fatal error....".
I appreciate any sugestion.
without seeing your code or knowing where you have made your declarations,
its difficult to ascertain where the problem may lie.
"gheor" wrote in message news:[email protected]...
error....".
In the help files there is a section titled Guidelines for Writing Event Handlers which states not to use interactive functions such as SendCommand.
Have you looked at AcadDoc.lsp instead of Acad.lsp?
Regards - Nathan
