Drawing is Busy
Drawing is Busy
eduardo.chavez
Observer Observer
Drawing is Busy
eduardo.chavez
Observer
Observer
Hello everybody
I have a problem with a Macro. I'm using Autocad 2008.
In my macro, I select a folder with DWG files and make a change on an object, save the file, but when I try close file, I get an error "Drawing is Busy" this is my code:
Private Sub cmdGenerar_Click()
    Dim oFile, fs, obj
    Set obj = CreateObject("Wscript.Shell") 'Objeto para las preguntas
    Set fs = CreateObject("Scripting.FileSystemObject")
    For i = 0 To lstArchivo.ListCount - 1
        lstArchivo.ListIndex = i                        'This is a lst with the file in the folder
        cfileDWG = txtCarpeta.Value & "\" & lstArchivo.Text
            Application.Documents.Open cfileDWG
             agregaSolDes ' Subrutine that make the change on object
            ThisDrawing.Save   'it's Work Ok
            ThisDrawing.Close    'I get an error and I cann't cotinue
    Next
End Sub
Thanks you.
Mike.Wohletz
What do you get if you try ThisDrawing.Close(False)
or replace the save line with ThisDrawing.Close(True, ThisDrawing.FullName)
