Dimensions Dimscale Scalefactor
rjay75
rjay75
I've created a block definition that include dimensions as part of the definition along with other objects. Regardless of what the Dimscale in the drawing or the scalefactor of the individual dimensions are set to the dimension are scaled to a factor of 1. The blocks reference is inserted immediately following the defining or redefining of the block. Any help will be appreciated.
I've had problems with dimensions in blocks in the past. Try creating the dimension in model space and then using CopyObjects to copy it into the block.
rjay75
