Difficulty understanding UCS behavior.
Here is what I did (See code Below)
On the bottom when I look at the values of .Origin(0 to 2) it gives me
(-450,-350,1450)
But nothing appends when I change the origin 0,0,0
Is there something missing in my code?
Thanks.
basePt(0) = Section
basePt(1) = ptCad(0)
basePt(2) = ptCad(1)
Xaxis(0) = basePt(0)
Xaxis(1) = basePt(1) + 10#
Xaxis(2) = basePt(2)
Yaxis(0) = basePt(0)
Yaxis(1) = basePt(1)
Yaxis(2) = basePt(2) + 10#
Set colUcs = ThisDrawing.UserCoordinateSystems
Set Ucs = colUcs.Add(basePt, Xaxis, Yaxis, "2D_" & Section)
Org = Ucs.origin(0)
Org = Ucs.origin(1)
Org = Ucs.origin(2)
ptCad(0) = 0
ptCad(1) = 0
ptCad(2) = 0
Ucs.origin = ptCad
From .ActiveUCS property in VBA online help...
"Changes made to the current active UCS will become visible only after that
UCS is reset as the active UCS. To reset the active UCS, simply call this
property with the updated UCS object."
Try:
> Ucs.origin = ptCad
Thisdrawing.ActiveUCS = Ucs
Good luck,
James
