delete empty layer filters - messages here, file moved
The original of this message with attached file has been moved to
the Customer Files area
(news://discussion.autodesk.com/autodesk.autocad.customer-files
or http://discussion.autodesk.com/WebX?14@172.mqhQa8ygo0H.17@.ee940b5). Please do
not post files into VBA, LISP or ARX sections larger than 16k. Zipping files is a
courtesy to those who download them.
See the newsgroup guidelines at
http://discussion.autodesk.com/webx?groundrules.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
       Date:
            Thu, 20 Mar 2003 09:50:00 -0800
            "Lambertus Oosterveen"
 Newsgroups:
            autodesk.autocad.customization.vba
Is it possible to delete all EMPTY layer filters?
I've already found 2 routine that can delete ALL named layer
filters, but
that's too much.
Lambertus
Attachments: nlfk.dvb
 DelLayrFilter.dvb
Lambertus -
Since one is my app, I can modify it so you can select the layer filters
to delete, but basically there is no such thing as a blank layer filter.
Saving the layer filter without any options still creates a 'non' empty
filter.
Mike
___________________________
Mike Tuersley
AutoCAD Clinic
Rand IMAGINiT Technologies
Mike,
You're right!
But what I mean is the result of the named layer filter(s).
If that's empty, the layer filter may be deleted/killed.
Lambertus
Yes, I am aware of what you mean. What you need to understand is that
the filters store the filtering criteria - not the collection of layers
that meet that filtering criteria. It might be possible to do what you
want, but, at the moment I am swamped at my day job [which is spilling
way over into my night hours]. To accommodate your request, I can
quickly change the app to allow you to individually select which ones to
remove until I have enough time to research and change the app to do the
specific functionality that you wish.
Mike Tuersley
AutoCAD Clinic
Okay!
I think you can make lots of CAD managers happy if you can change the app
the way we want.
Have a nice working day!
Royal Huisman Shipyard
