Diesel Directory
Diesel Directory
Message 1 of 8
Diesel Directory
Is there a way, possibly Diesel, to put in a field the directory of a file, not the entire path?
David
Replies (7)
Message 2 of 8
ska67can
vba code:
Dim fileLen, foldLen As Variant
Dim foldName As String
fileLen = Len(ThisDrawing.Name)
foldLen = Len(ThisDrawing.FullName)
foldName = Left(ThisDrawing.FullName, foldLen - fileLen)
Message 3 of 8
That works for VBA. But I want to have it be Diesel code within a Field in an Attribute.
David
Message 4 of 8
Well then, why are you in the VBA group? This question should be in plain
Customization.
FWIW, I don't think you are going to find an easy answer, unless you are on
2007 and can use an AutoLISP variable.
R. Robert Bell
wrote in message news:5417137@discussion.autodesk.com...
an Attribute.
David
Message 5 of 8
If you mean just the path to the drawing file,
but not the filename, then you don't need to
use DIESEL, you can use this field expression:
%<\AcVar Filename \f "%fn1">%
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5416810@discussion.autodesk.com...
David
Message 6 of 8
Tony, I think David is looking for "Stuff" in the case of
"C:\Temp\Stuff\Drawing.dwg".
R. Robert Bell
"Tony Tanzillo" wrote in message
news:5417767@discussion.autodesk.com...
Message 7 of 8
Robert,
Thanks for the clarification. That is exactly correct.
I am looking for "Stuff" in the case of "C:\Temp\Stuff\Drawing.dwg".
David
Message 8 of 8
In that case, pure DIESEL will probably not work
for what you need.
You can use a custom drawing property to store
any data you want, updated whenever needed or
appropriate, using LISP reactors or VBA events,
and you can reference that in your field.
I don't recommend using the LispVariable field
type, because LISP is not available in every
context where a field's value may be referenced.
wrote in message news:5417901@discussion.autodesk.com...
Robert,
David
