Delphi - Called lisp routine not working properly
DaSteelman
Message 1 of 1
DaSteelman
[AutoCAD 14 and Delphi 10.1 Berlin]
I call a List routine:
(DEFUN vrm_attsync_definition (blockname /)
; Original command I wanted
;(vl-cmdf "_.attsync" "_N" "VRM_SHAPEDEF")
; These commands work fine when lisp routine is called by command line or sendcommand?
;(vl-cmdf "_.circle" "5,4" "_d" 2.75) ;(command "_.circle" "5,4" "_d" 2.75) (princ "\nStart\n") (setq acad (vlax-get-acad-object)) (vla-put-windowstate acad acMin) (vl-cmdf "_.DELAY" 1000) (vla-put-windowstate acad acMax) (vlax-release-object acad) (princ "\nEnd\n") )
Note!: Everything works when lisp routine is called from command line.
When running my Delphi application everyting works exept for vl-cmdf and command...
In the active part everything is executed except for the delay.
Anyone an idea what is going on here?
Cheers!
Replies (0)
