Delphi Active Forms and EXD-files
Each time I change the color property of an ActiveForm written with Delphi 5
from the VBA IDE, let's say to red, it becomes impossible to change it back
to
the original color (or any other color) unless I first find and delete the
EXD-files for that ActiveForm. If I don't, the form color remains red, even
after
a save and reloading the project!?
Am I doing something wrong?
Is there a way to get rid of these EXD-files permanently? Some setting I
don't
know of? Rat poison?
Guido Rooms.
Guido - I don't believe there's anything you can do about
this. VBA creates these files for each control inserted,
and uses them to cache information that allows it to load
a control faster.
You can read more about this in knowledge base article:
Q158875
> to
> after
> don't
> Guido Rooms.
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Thanks for the reply Tony.
But this also means that if one changes an ocx or project and distributes it
to
one's users, they'll have to find and remove the EXD-files on their system,
or they'll never see the changes !?
Guido Rooms.
Tony Tanzillo wrote in message <389EC49B.7E8AC465@worldnet.att.net>...
>a control faster.
>Q158875
If they modify a persistent property of the control
in the IDE, that change should be written to the EXD
file, since that's essentially what it's for (caching
the properties of the control in the IDE). If that's
not hapening, there's a bug somewhere (possibly in
Delphi).
> to
> Guido Rooms.
> >a control faster.
> >Q158875
I read through the Knowledge Base article referenced which basically stated
that this would happen with Office 97 and 2000 products. However, I tried
several including Excel 97, Excel 2000, Word 2000 and AutoCAD 2000 and was
unable to generate an EXD file. After searching my hard drive I had only a
few with very old dates on them. So, I'm inclined to believe that this is
not normal behavior even though the MS article makes it seem that way.
Joe Sutphin
Author of "AutoCAD 2000 VBA Programmers Reference"
ISBN #1861002564
Checkout Sources - The magazine dedicated to AutoCAD customization
http://vbdesign.hypermart.net/sources/
news:389ED90B.79E25FF1@worldnet.att.net...
> Delphi).
distributes it
> > to
system,
> > Guido Rooms.
> > >a control faster.
> > >Q158875
I have a number of EXD files in my temp/vbe folder, and
they're not limited to Delphi-based ActiveX controls.
It looks pretty normal to me, although they may not be
created for all controls.
After trying tons of examples in Office 97, 2000, AutoCAD R14, 2000, MDT I
cannot simulate this occurance (in spite of what Microsoft's KB article
claims). The only conclusion that I am able to draw is that it must have
something to do with specific controls and perhaps what is used to build
them. I would query Borland for a possible answer.
Joe
Guido Rooms wrote in message
news:87lutm$eec10@adesknews2.autodesk.com...
5
back
> to
even
> after
> don't
> Guido Rooms.
