default values
default values
default values
I would like to have a 'default' button on a form that saves the value of a text box in vba, to its value property. So that the next time the macro is loaded and run the 'default' value is loaded. I know it is possible to load and unload references at runtime, but i'm not sure about changing form and control properties. This would save having to deal with writing and reading from another file which would also have to be maintained.
thanks
You type 'default' value into Text or Value
property of TextBox in Property Window while you design your form. By doing
this, whenever your form is loaded, the 'default value' is set in the text
box.
thanks
ok, now what i mean is... How do you change that Value property of the TextBox at runtime. I want to have a 'set as default' button that hard codes the new 'default' values into the vba code.
thanks
lorier
lorier had this to say:
> thanks
> lorier
Look into the SaveSetting and GetSetting functions to store your
information in the registry.
http://www.acadx.com
Store the value in the Registry... That's what it's
for...
Public Sub Userform1_Initialize ()
    TextBox 1 = Getsetting
("MyProgram", "MySettings", "MyKey", "MyDefaultValue")
End Sub
Public Sub Userform1_Deactivate()
    Savesetting (""MyProgram",
"MySettings", "MyKey", Me.TextBox1.value)
End Sub
ok,
thanks
lorier
Ed__Jobe
Another option is to save the value to a global variable in your module. The disadvantage to that is that the value will be cleared each time you unload the module or close acad. Sometimes its enough to save the variable for the current session only. -Ed
Ed
How to post your code.
Thanks Aaron! Didn't know it was that simple.
