Create text in Points Entities
I need to create a selection set with all the Points of DWG File.
Next step is create a text with the Z value of each point.
Best regards,
António Miranda.
Hello, Again
I've this code:
Private Sub CommandButton3_Click()
Me.Hide
Dim Pt As AcadPoint
Dim FilterType(0 To 0) As Integer
Dim FilterData(0 To 0) As Variant
Dim ssPoints As AcadSelectionSet
Dim DimText As String
Dim TextValue As String
FilterType(0) = 0: FilterData(0) = "Point"
Set ssPoints = CreateSelectionSet
ssPoints.Select acSelectionSetAll, , , FilterType, FilterData
DimText = 7.5
TextValue = "Write Here"
For Each Pt In ssPoints
ThisDrawing.ModelSpace.AddText TextValue, Pt.Coordinates, DimText
Pt.Highlight True
Next
ThisDrawing.Regen acAllViewports
ZoomAll
End Sub
Public Function CreateSelectionSet(Optional ssName As String = "ss") As AcadSelectionSet
Dim ss As AcadSelectionSet
On Error Resume Next
Set ss = ThisDrawing.SelectionSets(ssName)
If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
ss.Clear
Set CreateSelectionSet = ss
End Function
I need to replace the string TextValue to the Z value of each point, can anyone help me, please.
Best regards.
ok, thak's
Here the code:
Me.Hide
Dim VarPnt As Variant
Dim Pt As AcadPoint
DimText = 7.5
VarPnt = Pt.Coordinates
teste = VarPnt(2)
ThisDrawing.ModelSpace.AddText teste, Pt.Coordinates, DimText
Pt.Highlight True
Next
ZoomAll
End Sub
ss.Clear
End Function
