Create new textstyle if one doesn't exist
Message 1 of 8
I've learned how to create MText through VBA and utilize an existing Font Style, is it possible to have VBA check if a Font Style exists in the dwg? If so, it would continue the macro, if not then it would create a specified style. I can't find anything online about this other than directly changing an object's style upon creation, not about creating a style from scratch if the style doesn't exist.
 'CHECKED BY DATE
    Set MTextObj4 = ThisDrawing.ModelSpace.AddMText(corner4, widthN, text4)
        With MTextObj4
            .AttachmentPoint = acAttachmentPointMiddleLeft
            .InsertionPoint = corner4
            .StyleName = StyleName
            .Height = height1
        End With
 ... where StyleName = "PDF Search", the existing style.
Replies (7)
Message 2 of 8
Ed__Jobe
Here's a quick function. If it returns false, use ThisDrawing.Textsyles.Add()
Public Function HasTextStyle(StyleName As String) As Boolean
    Set HasTextStyle = False
    Dim name As String
    For Each name In ThisDrawing.TextStyles
        If name = StyleName Then HasTextStyle = True
    Next name
End Function
Ed
How to post your code.
Message 3 of 8
Thanks for the swift reply, Ed! When I plug in this code, it keeps stating "Object required". Adding a Dim call for HasTextStyle As Object yields a duplication.
Message 4 of 8
Ed__Jobe
You don't dim it. You're not creating an instance of the function, you just call it.
If HasTextStyle("MyStyleName") = false then
  Dim myStyle As AcadTextStyle
   Set myStyle = ThisDrawing.TextStyles.Add("MyStyleName")
   myStyle. 'set some style properties here
Ed
Message 5 of 8
norman.yuan
    Dim name As String
    Next name
End Function
The red line code should be:
HasTextStyle = False '' That is, "Set" should be removed, because the function's return type is a value type, not an Object type.
Norman Yuan
Drive CAD With Code
Message 6 of 8
Ed__Jobe
Oops, I thought I took that out. Thanks for catching it.
Ed
Message 7 of 8
Cool. I got the code to accept into the form, how can I call them function from a button in the same form? I get "Argument not optional" with direct calls of HasTextStyle on the button.
Message 8 of 8
I've been toying with our template border and the VBA layouts, here is what I have:
(This is to tie into my first posting here on the forums of Draw multiple lines )
What I have written requires a pre-existing Text Style of "PDF Search" (hence why I started this thread of how to verify/create).
Please let me know what you think.  When "Accept&Close" is clicked, the Subs are run back to back, there is a separate form for another part of the title block available.
