create and modify layers
Hi
I need some code to achieve the following:
-create layer 'Construction'
-modify color to red
-modify lineweight to 0.7mm
-modify printable to no
Thank you
Roman
Here is some code (not complete no lineweight an no printable)
Sub Layers()
Dim ConstructionAs AcadLayer
Set Construction = ThisDrawing.Layers.Add("Construction")
Construction.color = acred
On Error Resume Next
Call ThisDrawing.Linetypes.Load("hidden", "acadiso.lin")
line.Linetype = "hidden" (or some thing else)
End Sub
The code to set Layer colour does not work in versions of AutoCAD with
TrueColor. The help files have sample code to set the layer TrueColor
value.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5106230@discussion.autodesk.com...
Sub Layers()
End Sub
