auxiliary geometry on specific layer
Hi
What I want to do is the following:
-remember current layer
-activate layer 'Construction'
-draw construction line (as many as desired)
-when this task is finished or another command is selected by the user
then activate previous layer
Is this possible. Is this task
better done with LISP, but I have no idea of LISP.
My solution so far is:
^C^C-layer set Konstruktion;^C^C_xline hor
but I cannot set previous layer.
Thanks a lot
Roman
Hi Roman,
Paste the snip below in your "AcadDocument" code window. It should do what I
think you're asking.
Gary
Dim oPrevLayer As AcadLayer
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If UCase(CommandName) = "XLINE" Then
Set oPrevLayer = ThisDrawing.ActiveLayer
ThisDrawing.ActiveLayer = ThisDrawing.Layers("Construction")
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
If UCase(CommandName) = "XLINE" Then ThisDrawing.ActiveLayer =
oPrevLayer
End Sub
