converting existing 3d object to 3d mesh and increasing the size thru vba code
i want to convert existing 3d rectangle into surface and increase the u isolines and v isoline to improve the visibility in 2d wire frame. i am finding the function to convert the existing one. all vba coding is talk about creating the mesh surface by putting the information of vertex into point forms.
please let me any function in vba autocad to convert the object into surface-mesh and increasing its size.
Alfred.NESWADBA
First try to run the steps manually, then show us the dwg-file that shows each of the steps and let us know the commands you used. So we see the workflow you want to go.
Then please show us the code you have + point out which step is the one you are struggling with.
There are more objects that can be described as "surface" in AutoCAD, so please show us the entity you are really meaning, because a MESH does not have isoline parameters to change like you asked in the first question
Converting an object should not increase it's size .. what am I not understanding here?
- alfred -
PS: working in 3D means on my side I would not run in visual style "2D Wireframe". Raising the isolines just makes the display slower, but does not give you more accuracy
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
