Convert Series of Lines and Arcs to Plines
I have a series of lines and arcs that are intersecting. I need to be able to convert these to a Pline and set a width to this pline using vba. The width needs to reference a cell in excel.
Pseudo Code:
Select All Lines and Arcs
Convert Selected Lines and Arcs to one Pline
PEDIT --> Width --> Sheet1.Cells.(Width)
I'm fairly new at using VBA with AutoCAD. I feel like this shouldn't be that difficult to do but I cannot find anything so far. Any help would be greatly appreciated.
Methink you need to learn a bit more about VBA language,
say try from there http://www.afralisp.net/visual-basic-for-applications/
For this particular task try this one from my oldies
Option Explicit
' borrowed from Desmond Oshiwambo
' http://desmondoshiwambo.wordpress.com/2013/06/17/template-function-to-connect-to-excel-from-access-u...
Public Function GetExcelCellValue(xlFileName As String, xlCellAddress As String) As Variant
Dim cellValue As Variant
On Error GoTo ErrorHandler
Dim xlApp As Object
Dim xlWB As Object
Dim xlWS As Object
Dim xlRange As Object
Set xlApp = CreateObject("Excel.Application")
'Set xlWB = xlApp.Workbooks.Add
Set xlWB = xlApp.Workbooks.Open(xlFileName, False)
Set xlWS = xlWB.Worksheets(1) ' first sheet (or use "Sheet1" instead)
With xlWS
Set xlRange = .Range(xlCellAddress)
cellValue = xlRange.Value
End With
'Show Excel
xlApp.Visible = True
GetExcelCellValue = cellValue
GoTo CleanExit
ErrorHandler:
Debug.Print Err.Description
GetExcelCellValue = Nothing
CleanExit:
'Close Excel - do not save
If Not (xlWB Is Nothing) Then
xlWB.Close False
'Close workbook (don't save)
If Not (xlApp Is Nothing) Then
xlApp.Quit      'Quit
End If
End If
'Destroy objects
Set xlRange = Nothing
Set xlWS = Nothing
Set xlWB = Nothing
Set xlApp = Nothing
End Function
Sub JoinLines()
Dim oSsets As AcadSelectionSets
Dim oSset As AcadSelectionSet
Dim fType(0) As Integer
Dim fData(0) As Variant
Dim varPt As Variant
Dim oLine As AcadEntity
Dim oEnt As AcadEntity
Dim commStr As String
Dim intPt As Variant
On Error GoTo Error_Trapp
Dim pwid As Variant
pwid = GetExcelCellValue(ThisDrawing.GetVariable("dwgprefix") & "Test.xls", "a20") '<~~ change full path to Excel file and cell address
Dim strWidth As String
strWidth = Replace(CStr(pwid), ",", ".", 1, -1, vbTextCompare)
MsgBox "Select lines and arcs on screen"
Set oSsets = ThisDrawing.SelectionSets
fType(0) = 0: fData(0) = "LINE,ARC"
For Each oSset In oSsets
If oSset.Name = "LineSet" Then
oSset.Delete
End If
Next
Set oSset = oSsets.Add("LineSset")
oSset.SelectOnScreen fType, fData
ThisDrawing.SetVariable "PEDITACCEPT", 1
commStr = "_PEDIT _M"
For Each oLine In oSset
commStr = commStr & " (handent " & Chr(34) & oLine.Handle & Chr(34) & ")"
Next oLine
commStr = commStr & vbCr & " _Join 0.0000 "
commStr = commStr & "_Width " & strWidth & vbCr & vbCr
ThisDrawing.SendCommand commStr
'SendKeys "{ESC}"
oSset.Delete
Set oSset = Nothing
Error_Trapp:
If Err.Number <> 0 Then
MsgBox Err.Number & Err.Description
End If
End Sub
