Convert Paperspace drawings to Modelspace
Our company's standard is PaperSpace, but one of our customers demands all
files to be just ModelSpace. Does anyone have a VBA program that would look
at files and determine if there Paper or Model? If Paper is TRUE than to
run the express tool to convert: CHSPACE.
John Laidler
Cad Manager
Duckworth & Associates, Inc.
(734) 455-7500
Hi John - Just off the top of my head, if the drawing is completely done in
ModelSpace, then the PaperSpace collection should be empty, that is, in a VBA
routine: "ThisDrawing.PaperSpace.Count = 0". If it's not zero, then run CHSpace
I assume. (I've never used it.) Hope this helps...
...Colin French
> John Laidler
> Cad Manager
> (734) 455-7500
how in VBA can you execute an AutoCAD command??
I'm pretty new to VBA, if you haven't noticed.
John Laidler
Cad Manager
(734) 455-7500
"Colin French" wrote in message
news:[email protected]...
in
VBA
CHSpace
> ...Colin French
all
look
to
> > John Laidler
> > Cad Manager
> > (734) 455-7500
From the VBA help
Sub Example_SendCommand()
' This example sends a command to the AutoCAD commandline
' of a particular drawing for evaluation
' We will create a Circle in the active drawing and will
' zoom to display the entire circle
ThisDrawing.SendCommand "_Circle" & vbCr & "2,2,0" & vbCr & "4" & vbCr
ThisDrawing.SendCommand "_zoom" & vbCr & "a" & vbCr
' Refresh view
ThisDrawing.Regen acAllViewports
MsgBox "A circle command has been sent to the command line of the current
drawing."
End Sub
Bernard
ATC
45700 Villemandeur
France
John Laidler a écrit dans le message :
> John Laidler
> Cad Manager
> (734) 455-7500
> in
a
> VBA
> CHSpace
> > ...Colin French
demands
> all
would
> look
> to
> > > John Laidler
> > > Cad Manager
> > > (734) 455-7500
Hello folks,
With VBA this should be easy to write. Try the Layout collection and
property. Modelspace or "Model" is the last number of the Layout collection,
if I remember well.
Try for example:
Dim objLayout as AcadLayout
With ThisDrawing
Set objLayout = .Layouts(.Layouts.Count - 1)
ThisDrawing.ActiveLayout = objLayout
End With
Henk
Bernard Flavignard schreef in berichtnieuws
> From the VBA help
> ' Refresh view
current
> drawing."
> End Sub
> Bernard
> ATC
> 45700 Villemandeur
> France
> > John Laidler
> > Cad Manager
> > (734) 455-7500
done
> > in
in
> a
> > VBA
run
> > CHSpace
> > > ...Colin French
> demands
> > all
> would
> > look
than
> > to
> > > > John Laidler
> > > > Cad Manager
> > > > (734) 455-7500
Ooh, I see another posting with answers that go a very different direction
(I think I misunderstood your problem). It keeps tricky: multiple posts with
the same subject.
Greetings,
Henk
the program needs to convert Paperspace entities to Modelspace. I have most
of the code, now I just need to add code so when it detects more than 1
viewport it will select the first viewport created.
here is the code so far:
Public Sub ConvertDrawing()
Dim objLayout As AcadLayout
Dim objLayouts As AcadLayouts
Set objLayouts = ThisDrawing.Layouts
If ThisDrawing.ActiveSpace = acPaperSpace Then
ThisDrawing.SendCommand "CHSPACE" & vbCr & "all" & vbCr & vbCr
Else
End If
End Sub
John Laidler
Cad Manager
(734) 455-7500
"Henk Loonstra" wrote in message
with
> the same subject.
> Greetings,
> Henk
