Convert objects to revcloud
I'm trying to convert a closed 2D polyline into a revcloud (like using the command Revcloud > Object).
But it seems there's no VBA command to draw a revcloud.
So I had the idea to add bulges between each vertex, but with this solution my cloud's arcs can be very small...
Has anyone tried to make a macro doing this?
Any other solution to submit?
PS: Here is my code :
If Entity.Layer = "RevCloud" Then
   If Entity.EntityType = acPolyline Then
      NumberVertices = 0
      vCoord = Entity.Coordinates
      For Each Dcoord In vCoord
         NumberVertices = NumberVertices + 1
      Next
      NumberVertices = NumberVertices / 3
      If Entity.Type <> acSimplePoly Then
         Entity.Type = acSimplePoly
      End If
      For nIndex = 0 To NumberVertices - 1
         Entity.SetBulge nIndex, -1
      Next
   End If
End If
Alfred.NESWADBA
maybe I don't understand the question, but with your algorythm the arcs are as small(as large) as the distances between the vertices are. So the decission would be to remove some vertices if the distance between the vertices is to small (or to add some vertices to get smaller arcs).
BTW: your code does not round up the last two segments. Smiley Happy
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Yes, I though about this solution, but I didn't find the command to do that... Smiley Indifferent
Is there any way to remove vertices easily? Because I will need to check the spacing between two vertices...
Really? I didn't saw that problem...
Alfred.NESWADBA
it's just an array-handling. You have the property ".Coordinates" for the POLYLINE, that's an array of doubles (be carefull about the difference between LW-Polyline and Polyline (2D)). Remove items from this array (means remove vertizes from poly) and assign the new array back to the POLYLINE.
This example shows how to eliminate the last vertex from a LWPOLYLINE:
   Dim tPoly As AcadLWPolyline
   Dim tPnt As Variant
   Dim tCoords As Variant
   Call ThisDrawing.Utility.GetEntity(tPoly, tPnt)
   tCoords = tPoly.Coordinates
   ReDim Preserve tCoords(UBound(tCoords) - 2)
   tPoly.Coordinates = tCoords
HTH, - alfred -
Alfred NESWADBA
