common dialog woes!
common dialog woes!
Message 1 of 15
common dialog woes!
I used to have access to MS common dialog controls for my VBA applications.
I always assumed it was because I have Visual Studio.net on my machine but when I got a new computer I no longer have access to the common dialog control even though I have Visual Studio.net on the new machine also.
I tried Regsvr32 comdlg32.ocx. It said it's registrered but it still won't work in VBA
I just don't get it.
Replies (14)
Message 2 of 15
Even if you have it on your machine it isn't licenced to be used with VBA. You should be able to find a solution somewhere here http://discussion.autodesk.com/search!execute.jspa?numResults=25&source=viewforum%7C33&q=commondialog&objID=f33&search=Search
Regards - Nathan
Message 3 of 15
Thanks Nathan, but a couple of years ago I found either here or the msdn link a posting that describes exactly how to license it and from then on I was able to use it.
Now that I've changed computers I'm back to square one.
Message 4 of 15
sdanis wrote: > Thanks Nathan, but a couple of years ago I found either here or the msdn link a posting that describes exactly how to license it and from then on I was able to use it. Why bother when there's plenty of open-source replacements with no licensing restriction? -- There are 10 kinds of people: those who understand binary and those who don't.
Message 5 of 15
Could you perhaps point out where some of these "free" replacements can be found.
Thanks.
Message 6 of 15
Joe ...
wrote in message news:5557434@discussion.autodesk.com...
found.
Thanks.
Message 7 of 15
Thanks Joe. I am trying use your book to write some programs and I am fairly new to VBA. Your book is the primary resource I have found and it is very useful.
Scott
Message 8 of 15
So far I am making progress. However, once I get the file selected my objBlockRef will not set a value. The line I am using is:
set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(varInsertionPoint, FileSelected, dblX, dblY, dblZ, dblRotation)
FileSelected has the value from ShowOpen, but it is not being recognized. Any thoughts on this?
Thanks.
Scott
Message 9 of 15
is it in your support path? does it have the full path?
wrote in message news:5558288@discussion.autodesk.com...
Thanks.
Scott
Message 10 of 15
Yes. It works up to the point where it is supposed create the objBlockRefence object. FileSelected has the file name with path as a string and should be able to create the object using the call ThisDrawing.ModelSpace.InsertBlock command. The code is listed below. The ShowOpen is a call to the code Joe Sutphin provided in an earlier post.
I am beginning to wonder if I should use ThisDrawing.Add to first create an objBlockRef and then try to insert it?
Private Sub btnOpenFile_Click()
Dim objBlockRef As AcadBlockReference
Dim varInsertionPoint As Variant
Dim dblX As Double
Dim dblY As Double
Dim dblZ As Double
Dim dblRotation As Double
Dim usr3 As Double
usr3 = ThisDrawing.GetVariable("USERR3")
dblX = usr3
dblY = usr3
dblZ = usr3
dblRotation = 0
varInsertionPoint = "0,0,0"
' InsertBlock.Show
Dim Filter As String
Dim InitialDir As String
Dim DialogTitle As String
Dim FileSelected As String
Filter = "Drawing Files (*.dwg)" + Chr$(0) + "*.dwg" + Chr$(0) + "All Files (*.*)" _
+ Chr$(0) + "(*.*)" + Chr$(0)
InitialDir = "S:\Shared\Elec\Acade 2006"
DialogTitle = "Open a DWG file"
FileSelected = ShowOpen(Filter, InitialDir, DialogTitle)
Me.hide
'create the object
On Error Resume Next
Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(varInsertionPoint, FileSelected, dblX, dblY, dblZ, dblRotation)
If Err Then
MsgBox "Unable to insert this block."
Exit Sub
End If
objBlockRef.Update
Me.Show
End Sub
Message 11 of 15
Hopefully this will help narrow the focus on the problem I am having. I moved the On Error code to after the InsertBlock code and the following error code popped up:
Run Time Error '5'
Invalid procedure call or argument.
Anyone got an idea why I am getting this error?
Thanks.
Message 12 of 15
One more thing. When I look at the value of the variable FileSelected, a string, it has a box at the end of the text and before the close quotes. I am curous what that is and why is it there? Is it what is causing my error?
Thanks.
Message 13 of 15
Dim InsertionPoint(0 To 2) As Double
InsertionPoint(0) = 0: InsertionPoint(1) = 0: InsertionPoint(2) = 0
The insertion point is not a string value as you have it.
Joe ...
wrote in message news:5558921@discussion.autodesk.com...
Dim dblX As Double
Dim dblY As Double
Dim dblZ As Double
Dim usr3 As Double
dblX = usr3
dblY = usr3
dblZ = usr3
dblRotation = 0
' InsertBlock.Show
Files (*.*)" _
Me.hide
'create the object
If Err Then
Exit Sub
End If
objBlockRef.Update
Me.Show
End Sub
Message 14 of 15
Voila, that took care of the problem. Thanks.
Message 15 of 15
You're quite welcome.
Joe ...
wrote in message news:5559627@discussion.autodesk.com...
