Com Object and AutoCAD Electrical
Does anyone knows how a "vertical" can be loaded.
It's no problem to launch "Vanilla" Acad, but I also need the Eelctrical functionality.
The problem is that none of the AutoCAD Electrical functionality is loaded.
It gives the following message in the prompt.
AutoCAD Electrical menu utilities ; error: no function definition:
WD_ARX_FORMAT_PATH
This is occuring when I use the following code in Excel:
Option Explicit
Private Sub OpenAutoCAD(AutoCAD As AcadApplication)
On Error Resume Next
'attempt to open running AutoCAD
Set AutoCAD = GetObject(, "AutoCAD.Application")
If Err Then
Err.Clear
'AutoCAD not running, attempt to start
Set AutoCAD = CreateObject("AutoCAD.Application")
If Err Then
'AutoCAD cannot be started, exit
MsgBox "Error, AutoCAD cannot be executed", vbCritical, "Error loading AutoCAD"
On Error GoTo 0
Exit Sub
End If
End If
'make running AutoCAD visible
AutoCAD.Visible = True
End Sub
Public Sub Main()
Dim oAcad As AcadApplication
'open AutoCAD first
OpenAutoCAD oAcad
'then create my stuff
End Sub
If I start AutoCAD Electrical with the icon it works ok, but as soon if I automate it goes wrong. Although it looks the correct profile is loaded.
Does anyone has an idea to get it running?
You code simply start a "Vanilla" Acad instance, which does not know
anything about Electrical at all, of course.
I does not know how Electrical is loaded into Acad. If it is loaded through
a specific profile (very likely), then after acad started, you simply use
AcadPreferencesProfiles object to load required profile (
You can find the profile name by right-click the
shortcut->properties->Target text box.
It should read like this:
[Acad installation path]\Acad [Electrical\acad.exe /p [profileName]
wrote in message news:5749491@discussion.autodesk.com...
functionality.
WD_ARX_FORMAT_PATH
Option Explicit
If Err Then
Err.Clear
If Err Then
AutoCAD"
On Error GoTo 0
Exit Sub
End If
End If
End Sub
Public Sub Main()
'open AutoCAD first
OpenAutoCAD oAcad
End Sub
Hi Norman Yuan,
Thanks for your answer, the problem is not to load the profile, I tried that also but I'm still getting this error message with AutoCAD Electrical 2008:
WD_ARX_FORMAT_PATH
If I use the same code but then first startup and close Acad E 2007, it runs fine for the Electrical 2007 version.
So my guess is that Autodesk has changed something in his code.
