Collection1 - Collectoin2 = Collection3?
mdhutchinson
Advisor Advisor
mdhutchinson
Can anyone point me to a function, or give me some idea how I might write a function that will do the following?
Collection#1 minus Collection#2 returns Collection#3
The first thing that comes to my mind is
pseudocode:
for each object in Collection_2
if (object is in Collectioon_1) then
' Nothing
else
' Put the index in Collection_1 of that object into
' a collection of index called Collection_Index
end if
next
for each index in Collection_Index
Collection_1.Remove index
next
end of pseudocode
Note: you can't remove items from a collection you iterate in. Oh,
Collection_1 and Collection_2 should contain the same kind of objects.
Gilles Plante
wrote in message news:[email protected]...
I did this:
Public Function FilterSelectionSets(ssLocal As AcadSelectionSet, ssLocalTol As AcadSelectionSet)
Dim oPoly As AcadPolyline
Dim oPoly2 As AcadPolyline
Dim iCount As Integer
Dim aryItems() As AcadEntity
If ssLocal.Count > 0 Then
iCount = 0
For Each oPoly In ssLocal
For Each oPoly2 In ssLocalTol
If oPoly2.Handle = oPoly.Handle Then
' This is the same entity - we want to remove
' Increase array size
ReDim Preserve aryItems(0 To iCount)
' Add to array
Set aryItems(iCount) = oPoly2
' Update for next match
iCount = iCount + 1
Exit For
End If
Next
Next
ssLocalTol.RemoveItems aryItems
Erase aryItems
End If
End Function
On Thu, 01 Feb 2007 21:04:47 +0530, Gilles Plante wrote:
It is possible to remove items from the collection that you are iterating
if you do it in the reverse direction
FOR i = Collection.count - 1 to 0 STEP -1
rem - it possible to do anything in this loop that removes an item from
the collection
next i
rgds
Dilip Damle
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
