collection / array question
I have a list of numbers I need to sort.
I have Chris Rhea?'s Bubble sort routine I adapted for doubles.
That wants an array(variant) as input.
Not knowing the length of the list I either need to redim multiple times or
put in a collection, get the count and then redim once to the size I need.
I'm wondering which is better, a collection and one redim, or just one array
with multiple redims?
How much does it cost to create a collection that I'm just going to stick
into an array anyway?
Or can i sort a collection - I guess the bubble sort idea could be adapted
to work with a collection object.
Or is that plaigarism to rework something like that if you retain the
original credits info in the modified code?
Or does any of this make any sense?
Thanks for any inspirations.
Mark
Try searching the MSDN (msdn.microsoft.com) for sorting algorithms. Here's
one hit (watch for wordwrap):
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpref/html/
frlrfSystemArrayClassSortTopic1.asp
Rune Wold
System Analyst
Engineering Systems
rune@engsys.no
What format is the list in that you don't know it's size? Multiple Redim's
are not recommended if you are after performance. Doing a redim on for every
item is very slow. One idea would be to process the list once, doing nothing
but getting the count - then create the array the correct size and process
the list again, populating the array.
You can reuse the sorting code if it's something that someone posted. Even
if you modify it, including the credit is a good idea.
Glen
"MP" wrote in message
news:8F784FD741BB7C4A47572095470042E1@in.WebX.maYIadrTaRb...
> Hi,
or
array
> Mark
"Glen Albert" wrote in message
news:1CC4F5715B4638838222AA8C1C57D02D@in.WebX.maYIadrTaRb...
I'm reading it out of a dictionary which was populated by an earlier sub.
> Multiple Redim's are not recommended if you are after performance.
that's what I've heard
>Doing a redim on for every item is very slow. One idea would be to process
the list once, doing >nothing but getting the count - then create the array
That's what I'm doing by putting them in a collection first, then getting
the .Count. I was just checking if that is the correct proceedure. (it still
seems like double work to me)
I'll check the link posted by Rune, maybe I can sort the collection.
I guess I could just do a foreach on the xrecords and increment an integer
count but then i'd have to go back through it a second time to put them in
the array but that seems really stupid.
or (duh) the .Count of the dictionary! what a concept! :)~
> Glen
cool
thanks for the response
Mark
Rune,
Thanks I'll check it out!
Mark
