codes to change the name of a blockref object in vba
hi,
i tried several times,but failed.
could anybody give me the codes to change the name of a blockref object in
vba.
thanks, in advance.
what have you tried?
you cannot change the blockref name,
you can change the name of the blockdef
from which the blockref is created from.
"youngman" wrote in message
news:4859834@discussion.autodesk.com...
hi,
vba.
thanks, in advance.
You can change the name of the block ref to that of another defined
blockdef, and that block ref will change to the other block.
"Paul Richardson" wrote in message
news:4859952@discussion.autodesk.com...
hi,
vba.
thanks, in advance.
