Closing a program that is open
Message 1 of 11
If you havent read my last post I'm working on a program and part of what it
does is opens and closes ACAD for the user. I'm having trouble getting this
VBS to close ALL instancess of CAD. Would anyone have an ideas on how to do
this?
I thought it might be as simple as
>CODE
Dim WshShell
' Create a WSH Shell object.
Set WshShell = _
CreateObject("WScript.Shell")
' Close AutoCAD application.
WshShell.close _
"""C:\Program Files\Autodesk Architectural Desktop 3\acad.exe""", _
1, _
True
>CODE
But i'm obviously wrong
Replies (10)
Message 2 of 11
GTVic
Are you sure this is a good idea. What if the dwg is not saved or a command is active? In those cases the application won't close.
I couldn't find a Close method for the WsShell object:
Microsoft link -> http://tinyurl.com/5e7gh
Here is some code I found using Google: (link -> http://tinyurl.com/7dmnv)
[code]
Set colProcessList = objWMIService.ExecQuery ("SELECT * FROM Win32_Process WHERE Name = 'acad.exe'")
For Each objProcess In colProcessList
objProcess.Terminate()
Next
[/code]
Message 3 of 11
I was thinking about the ALT+F4 close command because that will prompt for
save|yes/no.
>CODE
AppActivate("ACAD.exe")
SendKeys "%{ }{ALT}{F4}", 0 'ALT, F4
>CODE
But this code I made is wrong and I think its in the send keys line. My
Keys names are messed up.
The command that is listed in the post, the "objProcess.Terminate" command..
I think that will just end CAD with out prompting for save if I understand
it correctly.
And I am getting a runtime error on it too, when I tried it out.
Any ideas on the send keys command OR the Terminate command?
wrote in message news:4823878@discussion.autodesk.com...
> [code]
> Next
> [/code]
Message 4 of 11
ok.. so now I'm down to this...
>CODE
AppActivate "acad"
SendKeys "%{F4}"
>CODE
I've tried Autodesk Architectural Desktop 3.3 and acad.exe and on both I
get a "type mismatch" on the AppActive line.
Anyone help please
"AlmightySR" wrote in message
news:4824526@discussion.autodesk.com...
>save|yes/no.
>>CODE
>>CODE
> command.. I think that will just end CAD with out prompting for save if I
> understand it correctly.
>> [code]
>> Next
>> [/code]
Message 5 of 11
Much the same advice as before - you probably don't really want to do this but here's a nice length of rope:
Dim Acad
On Error Resume Next
Do
Set Acad = Nothing
Set Acad = GetObject(, "AutoCad.Application")
Acad.Quit
Loop Until Acad Is Nothing
And now for a question: Do you have access to any documentation?
Message 6 of 11
documentation for?
wrote in message news:4824590@discussion.autodesk.com...
> Dim Acad
> Do
> Set Acad = Nothing
> Acad.Quit
Message 7 of 11
WSH?
Acad VBA?
VBS?
Message 8 of 11
I donthave thoughs... I'm learning thru the internet and helpful groups like
this. This is actually the first program I have ever made... Dis-counting
batch files.
wrote in message news:4824712@discussion.autodesk.com...
> WSH?
> Acad VBA?
> VBS?
Message 9 of 11
WSH:
Acad VBA:
acad_aag.chm in the Help directory of a machine with Acad.
VBS:
Message 10 of 11
That command you sent me is working great! thank you
wrote in message news:4824933@discussion.autodesk.com...
> WSH:
> Acad VBA:
> VBS:
Message 11 of 11
I mean "code"
news:4825049@discussion.autodesk.com...
>> WSH:
>> Acad VBA:
>> VBS:
