Close sheet set - or force a refresh?
GilesPhillips
GilesPhillips
TL:DR how do I close a sheet set?
The following code does nothing (no crashes, just smiles and nods..)
Public Function RefreshSheetSet(SSfilename As String) As String
On Error GoTo ErrorRefresh
Dim OSSM As New AcSmSheetSetMgr
Dim DbIter As IAcSmEnumDatabase
Dim DB As AcSmDatabase
Dim CurSSet As AcSmSheetSet
Dim Retval
Dim SSFile As String
'refreshes current sheet set
Set DbIter = OSSM.GetDatabaseEnumerator
If DbIter Is Nothing Then
    'ssm not loaded
    RefreshSheetSet = "Sheetset manager not loaded"
    Exit Function
DbIter.Reset
Set DB = DbIter.Next
If DB Is Nothing Then
    Refreshseetset = "No Sheetset loaded"
    Exit Function
Else
    Do While Not DB Is Nothing
        SSFile = DB.GetFileName
        If SSFile = SSfilename Then
            Set CurSSet = DB.GetSheetSet
            OSSM.Close DB
            'Set DB = OSSM.OpenDatabase(SSFile)
            RefreshSheetSet = "Sheetset re-loaded"
            Exit Do
    Loop
Exit Function
ErrorRefresh:
DB.UnlockDb DB
RefreshSheetSet = Err.Description
End Function
Background:
Due to circumstances beyond my control our drawing filesystem is hosted on the cloud, with filesystem access provided by cloud drive mapper by IAM
Everything works, albeit slowly, but adequately, apart from a custom vba script to insert a sheet into the current sheet set - the sheet set manager doesn't reflect the change until it's closed and re-opened.  In the absence of any better ideas, I thought I'd just get the script to close and then re-open the sheet set.  Easier said than done.
Any suggestions on closing the sheet set?
ACad, MEP, Revit, 3DS Max
daniel_cadext
AcSmSheetSetMgr should have a close function. I have this in my Python test.
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
