CONVTOSURFACE in VBA
saboh12617
Message 1 of 1
saboh12617
Quick question: I was looking for the VBA equivalent of AutoCAD 2024 Help | CONVTOSURFACE (Command) | Autodesk function.
But I can not find it. Also I read at the very bottom of the Surface's Object § Remarks (AutoCAD 2024 Developer and ObjectARX Help | Surface Object (ActiveX) | Autodesk) that "You cannot create a surface entity via ActiveX.". I suppose that is the reason. Is it correct? Thank you in advance.
Replies (0)
