Close Method
Close Method
Message 1 of 14
Close Method
The close medhod stops the execution of my VBA program.
I am in a drawing and run a VBA program. The program opens up an existing drawing extracts out some block information, closes the drawing then attempts to use the information in the current drawing. Yesterday it would not work then it started working for some unknow reason. Now today it doesn't work. The code works fine if I comment out the close command.
What am I doing wrong.
Wayne Lefferd
Replies (13)
Message 2 of 14
Wayne:
What version of AutoCAD are you using?
What is the value of your SDI variable?  (This determines if you can
have multiple drawings open.) If you could post your code it might help diagnose
the problem.
Andy Roe
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">The
Wayne Lefferd
Message 3 of 14
If you have no document open after you execute the Close
method
then that is your problem. You will not be able
to interact with AutoCAD
without a Document object.
Joe
The
Wayne Lefferd
Message 4 of 14
This is a copy of most of the code. I have added as many comments as I can so someone might beable to follow it. there are 2 or 3 functions that are called that are in dll's and are not here.
Wayne Lefferd
Sub aaa()
Dim xxx As Variant
Dim Cnt As Integer
Dim XrefName As Variant
XrefName = wl.Get_XrefName 'returns an array of xref names in the drawing this function is in a dll and not here
xxx = Image_List_From_Xref(XrefName(0)) 'returns an array of the block names in the drawing that is xref in the drawing
' the program is not continuming beyond this point
If VarType(xxx) > 8000 Then 'check to see if the above function retruned an array or not
xxx(21, 0) = xxx(21, 0) ' the rest of this is just checking to see what was returned
xxx(21, 1) = xxx(21, 1)
xxx(21, 2)(0) = xxx(21, 2)(0)
xxx(21, 3) = xxx(21, 3)
xxx(1, 0) = xxx(1, 0)
Cnt = UBound(xxx)
Cnt = Cnt
End If
End Sub
Function Image_List_From_Xref(ByVal XrefName As String)
Dim ent As AcadEntity
Dim SSet1 As AcadSelectionSet
Dim TempSortedList As Variant
Dim TempArray() As Variant
Dim Cnt As Integer
Dim Image_Name As String
Dim TempUnSortedList As Variant
ThisDrawing.Application.Documents.Open XrefName + ".dwg", True ' opens the xref drawing in read only mode
TempUnSortedList = ImageBlock_List 'returns a list of the blocks in an unsorted older
If VarType(TempUnSortedList) > 8000 Then ' if there are no image blocks the function will return 0
TempSortedList = wl.ArraySorter(TempUnSortedList) 'sorts the array of block names. this function is in a dll and not here
ReDim TempArray(UBound(TempSortedList), 3) ' sets up a two dim array the length of the block list
For Cnt = 0 To UBound(TempSortedList) 'goes theough the sorted block name list looking for additional info about the blocks
Image_Name = TempSortedList(Cnt) 'gets an single block name to get info on
Set SSet1 = wl.Make_Selection_Set_All(0, "INSERT", 2, Image_Name) ' sets up a selection set for all inserted items with a certain named block
If SSet1.Count > 0 Then 'makes sure it found at least one block with the correct name
For Each ent In SSet1 'pulling off data from block
TempArray(Cnt, 0) = ent.Name
TempArray(Cnt, 1) = ent.Name
TempArray(Cnt, 2) = ent.insertionPoint
TempArray(Cnt, 3) = ent.XScaleFactor
Next ent
End If
Next Cnt
Image_List_From_Xref = TempArray 'sets up to return array if it has any information
Else
Image_List_From_Xref = 0 ' set up to return 0 if it found nothing
End If
ThisDrawing.Close , False 'closes the drawing and does not save, must have false because drawing opened in read only mode
' it works fine (except for closing the drawing) if I comment out this line
End Function
Function ImageBlock_List()
Dim Block_Names() As String
Dim Cnt As Integer
Set SSet1 = wl.Make_Selection_Set_All(0, "INSERT", 2, "Image_*") ' returns a selection set for all inserts in drawing with names starting with "Image_*"
If SSet1.Count > 0 Then ' stops if it found no matches
ReDim Block_Names(SSet1.Count - 1)
For Each ent In SSet1 ' getting name off blocks
Block_Names(Cnt) = ent.Name ' puts names in array
Cnt = Cnt + 1
Next ent
End If
ImageBlock_List = wl.ArraySorter(Block_Names) 'returns sorted array of block names. function not here its in dll
End Function
Message 5 of 14
The document that I had originally opened is never closed. When the program stops that drawing is on the screen.
Wayne
Message 6 of 14
What exactly are you getting for feedback from
AutoCAD?
Joe
This
Wayne Lefferd
Sub aaa()
Dim xxx As Variant
Dim Cnt As Integer
Dim XrefName As
Variant
xxx =
xxx(21,
xxx(21, 3) =
xxx(21, 3)
Cnt = UBound(xxx)
Cnt = Cnt
End If
End Sub
Dim ent As
AcadEntity
Dim Cnt As Integer
Dim Image_Name As
String
unsorted older
        TempSortedList =
        ReDim
the block list
            Image_Name
            Set
            If
correct name
                For
                    TempArray(Cnt,
0) = ent.Name
                    TempArray(Cnt,
1) = ent.Name
                    TempArray(Cnt,
                    TempArray(Cnt,
                Next
ent
            End
If
        Next Cnt
    Else
End If
ThisDrawing.Close ,
End Function
Dim ent As
AcadEntity
Dim Cnt As Integer
Set
              Block_Names(Cnt)
              Cnt
= Cnt + 1
    Next ent
End If
End Function
Message 7 of 14
My SDI is set to have multiple drawings open and I am useing autocad 2000. Would you happen to know if any of the VBA functions such as Purge or Explode have been fixed in 2002 or does all the functions work the same.
I put my code in another reply. I commented it as much as I could because the best of code is hard to follow and mine is not the best code.
Wayne
Message 8 of 14
It just stops no errors on comments on nothing. The program does not hang it just quits.
Message 9 of 14
I guess I should of said AutoCad is still running my VBA program just stops.
Message 10 of 14
What are you expecting it to do after the .Close
method?
Where is the code for that?
Joe
I
stops.
Message 11 of 14
In the sub aaa there is a line
That function has the close method in it and should return
a multi dim array.
the line below that
check to see if it returned an array or not
the lines below that are just reading the array if it returned one.
What I am doing to see it it is working is in the VBA editor
putting one of the brown dots in the margin which stops the execution of the code at that spot and lets you read the variables before it in that sub or function it was stopped in. If the line I choose to stop on is not run it does not stop. I should be able to stop on the line
because should run the If statement wether or not an array was returned. But the program goes right past the statement and terminates which makes me thing it has terminated before that. If I comment out the close statement it works fine except for not closeing the drawing.
Wayne
Message 12 of 14
My suggestion would be to open the DWG file outside
of the AutoCAD editor using the AxDbDocument object. (You need to register
AXDB15.DLL on your machine.)
In
a multi dim
array.
the line below that
check to see if
putting
Wayne
Message 13 of 14
Wayne:
I took a look at your code, but it's difficult
to diagnose what's going on if you have additional DLLs that aren't included in
your posting.  If you'd rather not post that code, you can email the DLLs
and I could take a look.
Andy Roe
My
I put my code
Wayne
Message 14 of 14
Howdy,
Ok, here is your problem. You need to have code like the following to open
your drawing and assign your drawing to a variable.
'Assign the AcadDocument object to a variable. This will hold the drawing
that is currently being opened
Dim NewDWG as AcadDocument
'To open a dwg
Set NewDWG=application.documents.open (
here>)
'set this to ensure that the newly opened drawing is active and given the
focus
newdwg.activate
'to close the dwg without closing AutoCAD
NewDWG.close
"Jorge Lopez" wrote in message
news:3FAEE427B568B17D74869AE6DA620469@in.WebX.maYIadrTaRb...
My suggestion would be to open the DWG file outside of the AutoCAD editor
using the AxDbDocument object. (You need to register AXDB15.DLL on your
machine.)
"wlefferd" wrote in message
news:f06417c.9@WebX.maYIadrTaRb...
a multi dim array.
the line below that
Wayne
