Check Remote Server Name
Amremad
Amremad
    Dim oShell As Object
    Set oShell = CreateObject("Shell.Application")
    MsgBox Not CBool(oShell.NameSpace(CVar("\\ServerName")) Is Nothing)
 or
Private Declare Function PathIsDirectory Lib "Shlwapi" Alias "PathIsDirectoryW" (ByVal lpszPath As Long) As Long
Public Function DirExists(ByVal sDirName As String) As Boolean
  DirExists = (PathIsDirectory(StrPtr(Trim$(sDirName))) <> 0)
End Function
 this is two ways to check if server exist or not
but my a problem :
if server isn't exist this code talk long time and make my computer hung every time in (three or four time for ex.)
can i fix this problem??
Alfred.NESWADBA
you might use PING to see if the server is alive and can be found before you start any connections to it (>>>click<<<).
BTW: what has this question to do with "AutoCAD customization"?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
