AutoCAD becomes visible during SendCommand
Hey all,
I'm not sure why, but when I call the sub:
Public Sub BurstAll(doc As AcadDocument)
    doc.SendCommand ("BURST ALL " & vbCr)
End Sub
AutoCAD suddenly becomes visible (which is not desired).  Before this line of code, the application is not visible.
I'm curious as to why AutoCAD decides to randomly become visible even It wasn't previously.  Is this a bug? Or is there another step that I need to perform before I can call "SendCommand"
Your help is greatly appreciated!
God Bless,
- Nick
PS: If anybody can reproduce this behavior, I'm sure it'd greatly help.  Thanks again!
Alfred.NESWADBA
Just as a guess: this command asks for a selection, so I see it not as randomly but more as correct that when a selection is requested the user get's the application visible.
You might try to first select the blocks to purge with putting all blockreferences into the PICKFIRST selection set before you start the command _BURST as then it's no user-interaction necessary then (as long as blockreferences are selected), but I have not tried it, wether AutoCAD pops to front or not. It's just an idea.
The other option would be to write your own burst so you don't need SendCommand.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
