Changing modelspace views with VBA
I wish to provide a capability of swapping the view of the drawing
between "plan", "front elevation", "side elevation" and the standard
isometric views. Searching help files and the Object model I have not
been able to find an API for this. It seems an obvious item for there
to be an API.
I've been playing with "Sendcommand" as an alternative, but find it
unreliable in that sometime it works and other times it stacks the
commands and runs then when I exit my program.
Select Case Combobox.ListIndex
Case 0
ThisDrawing.SendCommand "-view" & vbCr & "_top" & vbCr
Case 1 '<--- "Front elevation"
ThisDrawing.SendCommand "-view" & vbCr & "_front" & vbCr
Case 2 '<--- "Side elevation"
ThisDrawing.SendCommand "-view" & vbCr & "_left" & vbCr
Case 3 '<--- "SW Isometric"
ThisDrawing.SendCommand "-view" & vbCr & "_swiso" & vbCr
Using vbcrlf or vbcr makes no difference.
Regards
Laurie Comerford
hi,
Could you do this with UCS's?
Sub Example_UserCoordinateSystems()
' This example finds the current UserCoordinateSystems collection and
' adds a new UCS to that collection.
Dim UCSColl As AcadUCSs
Set UCSColl = ThisDrawing.UserCoordinateSystems
' Create a UCS named "Top" in the current drawing
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPnt(0 To 2) As Double
Dim yAxisPnt(0 To 2) As Double
' Define the UCS
origin(0) = 0#: origin(1) = 0#: origin(2) = 0#
xAxisPnt(0) = 1#: xAxisPnt(1) = 0#: xAxisPnt(2) = 0#
yAxisPnt(0) = 0#: yAxisPnt(1) = 1#: yAxisPnt(2) = 0#
' Add the UCS to the UserCoordinatesSystems collection
Set ucsObj = UCSColl.Add(origin, xAxisPnt, yAxisPnt, "Top")
MsgBox "A new UCS called " & ucsObj.name & " has been added to the UserCoordinateSystems collection.", vbInformation, "UserCoordinateSystems Example"
End Sub
hope this helps
I just did this for someone else... you'll have to finish the iso views but I did SEISO...
[code]
Enum Views
TOPVIEW
BOTTOMVIEW
FRONTVIEW
BACKVIEW
LEFTVIEW
RIGHTVIEW
SEISO
End Enum
Function ViewVector(v As Views) As Double()
Dim temp(2) As Double
'not need to set valuse that are zero. just
'set the vector direction
Select Case v
Case Views.TOPVIEW
temp(2) = 1
Case Views.BOTTOMVIEW
temp(2) = -1
Case Views.FRONTVIEW
temp(1) = -1
Case Views.BACKVIEW
temp(1) = 1
Case Views.LEFTVIEW
temp(0) = -1
Case Views.RIGHTVIEW
temp(0) = 1
Case Views.SEISO
temp(0) = 1
temp(1) = -1
temp(2) = 1
'to get the rest set your view and type viewdir.
End Select
ViewVector = temp
End Function
Sub foo()
ThisDrawing.ActiveViewport.Direction = ViewVector(Views.SEISO)
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
End Sub
[/code]
"Laurie Comerford" wrote in message news:6028607@discussion.autodesk.com...
to be an API.
Case 0
Regards
Laurie Comerford
Hi Paul and Cadger,
Thank you. Cadger for helping me understand what I was doing and Paul
for the code. I can see my knowledge of AutoCAD UCSs was defective.
They are not normally needed in Civil.
I've transformed Paul's code into my Case statement and all is well.
' Pass this the ComboBox index
Function SetViewDirection(iIndex As Integer)
Dim daViewDirection(2) As Double
Select Case iIndex
Case 0 '<--- "Plan" - OK from Email
daViewDirection(0) = 0
daViewDirection(1) = 0
daViewDirection(2) = 1
Case 1 '<--- "Bottom" - OK from Email
daViewDirection(2) = -1
Case 2 '<--- "Left Side elevation" - OK from Email
daViewDirection(0) = -1
daViewDirection(2) = 0
Case 3 '<--- "Right elevation" - OK from Email
daViewDirection(0) = 1
Case 4 '<--- "Front" - OK from Email
daViewDirection(1) = -1
Case 5 '<--- "Back elevation" - OK from Email
daViewDirection(1) = 1
Case 6 '<--- "SW Isometric" - OK from AutoCAD
Case 7 '<--- "SE Isometric" - OK from Email
Case 8 '<--- "NE Isometric" - OK from AutoCAD
Case 9 '<--- "NW Isometric" - OK from AutoCAD
Case Else ' <--- Set to another view
daViewDirection(0) = -2.5
daViewDirection(2) = 2
End Select
ThisDrawing.ActiveViewport.Direction = daViewDirection
ZoomExtents
End Function ' SetViewDirection
Regards
Laurie Comerford
> [code]
> Enum Views
> TOPVIEW
> BOTTOMVIEW
> FRONTVIEW
> BACKVIEW
> LEFTVIEW
> RIGHTVIEW
> SEISO
> End Enum
> Select Case v
> Case Views.TOPVIEW
> temp(2) = 1
> temp(2) = -1
> temp(1) = -1
> Case Views.BACKVIEW
> temp(1) = 1
> Case Views.LEFTVIEW
> temp(0) = -1
> temp(0) = 1
> Case Views.SEISO
> temp(0) = 1
> temp(1) = -1
> temp(2) = 1
> End Select
> ViewVector = temp
> End Function
> Sub foo()
> End Sub
> [/code]
> Hi,
> to be an API.
> Case 0
> Regards
> Laurie Comerford
