change ESC function temporarly while using VBA
jalal.mousa
jalal.mousa
Is there a way to change ESC function from exit command  to Close (polyline) while using vba and then change it back to normal
can i access CUI under Keyboard Shortcuts ?
Ed__Jobe
That won't work, I don't think the {ESC} key is defined in the CUI. Using Windows api's, you can error trap for it and work around it, sort of skip over it. First you have to add the api's to your module, then in your sub, you need to add error trapping. The code below is copied from one of my sub's. Start with this, then set a breakpoint in your code. Start debugging and test by hitting {ESC}. Execution should jump to line 29. Step through to line 30. Hover  your mouse over the Err variable and see what the error code is. That's what you need in the Case statement at line 31. Then the code will test to see if the {ESC} was used and if it was, resume at the next line.
Option Explicit
'GetAsyncKeyState constants
Private Enum enGetAsyncKeyState
    VK_ESCAPE = &H1B
    VK_LBUTTON = &H1
    VK_RBUTTON = &H2
    VK_RETURN = &HD
    VK_SPACE = &H20
End Enum
Private Declare PtrSafe Function GetAsyncKeyState Lib "user32" (ByVal vKey As enGetAsyncKeyState) As Integer
Public Sub ErrorTrapExample()
  On Error GoTo Err_Control
  'Set up undo for this command
  ThisDrawing.StartUndoMark
  'start your process
  'do work
Exit_Here:
    ThisDrawing.EndUndoMark
    Exit Sub
Err_Control:
    Select Case Err.Number
    Case -2147352567
        If GetAsyncKeyState(VK_ESCAPE) > 0 Then
            Err.Clear
            Resume
'     Case -2145320928
'       'User input is keyword or..
'       'Right click
'       Err.Clear
'       Resume Exit_Here
    Case Else
        MsgBox Err.Description
        Resume Exit_Here
    End Select
End Sub
Ed
How to post your code.
jalal.mousa
Hi ED
this was a great solution to work with, not sure if it was clear in my previous post, but i am sending commands from Excel
I had to adjust code to work with my needs
not sure if i did mistake but if statement below was returning value 0 so i adjust it to = 0 so it can close object
'If GetAsyncKeyState(VK_ESCAPE) > 0 Then
 also i adjusted close command to edit last polyline and close it, as close by itself will close AutoCAD
'ThisDrawing.SendCommand "_pedit" & vbCr & "_select" & vbCr & "_LAST" & vbCr & "_CLOSE " & vbCr
new ESC function changes become
' ESC Function canges
'If GetAsyncKeyState(VK_ESCAPE) = 0 Then
''close command triggered
'closeKeyPressed = True
'End If
Ed__Jobe
Just be aware that SendCommand is asynchronous, i.e. it will run after your vba code has finished. So trying to prevent esc is pointless. To make it work, you would need to use the ActiveX api to modify the pline's properties.
Ed
