cell table prefix and suffix
jeremye86
Message 1 of 9
jeremye86
i have cell values in a table that are summed up with a formula.  How do i add a prefix and suffix to these values so they sill work with the sum formula
Sub Example_CellManipulation()
    Dim MyModelSpace As AcadModelSpace
    Set MyModelSpace = ThisDrawing.ModelSpace
    Dim pt(2) As Double
    Dim MyTable As AcadTable
    Dim cName As String
    Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 0.5, 0.5)
    MyTable.SetText 3, 4, "(" & 4 & ")"
    MyTable.SetText 4, 4, "=Sum(E1:E4)"
    ZoomExtents
End Sub
.  I am trying this and it is not working
Replies (8)
Message 2 of 9
Hello ,
Just looking at your code and comparing with Autdeskreference ,
and I don't see how this can work if pt hasn't been implemented before the set.
You need to give a point there.
Message 3 of 9
jeremye86
pt is just 0,0,0
there is no need to define pt if I want it to be 0,0,0
Message 4 of 9
pt has to be an array with content. If you give nothing it doesn't work.
Even if you don't care 😉
Message 5 of 9
jeremye86
It does work if you give nothing, I just tested it.  this is besides the point.  Is there even a solution to my question?  The formula gives #### error because it cant read text values.
Message 6 of 9
needs some research from you here. Good luck.
It's not to difficult to define the Cells. 😉
you will find by yourself.
Message 7 of 9
Ed__Jobe
This really isn't a vba question but a table cell macro question. If you can get it to work in xl using their macro functions, it should work in an acad table. Can you attach an xls with some samples of prefixed text you want to 'add'?
Ed
How to post your code.
Message 8 of 9
Ed__Jobe
I take that back. AutCAD tables don't support very many functions. You're best to create a table in xl and link the AutoCAD table to it. Then you can use xl's functions. I wasn't able to get a function to operate over a range like the Sum() function can. I had to create a column that first extracts the digits from the text, then sum that column. See the attached xlsx.
Ed
Message 9 of 9
jeremye86
Thinks Ed, I knew about linking excel tables, didn't want this as a solution.
The AutoCAD table Sum function works well for a range of cells.   The problem is that adding a prefix to a cell value with VBA changes the value to a string and thus the sum function no longer works.  The picture below shows how to add a prefix and suffix w/o VBA and still get the sum function to work.
