Cannot Get or Create AutoCAD App
meck
Message 1 of 9
meck
I have upgraded to AutoCAD 2015 and now I cannot get the app anymore. I'm getting the "Cannot Connect to ActiveX component" error. I assume it has something to do with versioning and I tried using AutoCAD.Application.19 but that doesn't work either. Is this the problem? If so how do I get the version? I looked in the Help/About but couldn't find anything.
Any help would be greatly appreciated!
I'm using VB.net 2010.
Below is my connection code...
Try
      oAcadApp = GetObject(, "AutoCAD.Application")
Catch
     Try
          oAcadApp = CreateObject("AutoCAD.Application")
          oAcadApp.Visible = True
     Catch ex As Exception
          MsgBox(ex.Message & " error while starting AutoCAD.", MsgBoxStyle.Exclamation, "Error Starting AutoCAD!")
          Exit Sub
     End Try
End Try
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
Replies (8)
Message 2 of 9
Ed__Jobe
Are  you creating a standalone exe? Is it 32bit and your acad 2015 is 64bit?
Ed
How to post your code.
Message 3 of 9
meck
Yes it is a stand alone exe.
AutoCAD is 64 bit.
All running on Windows 7.
Mike Eck
Using Inventor 2018
Message 4 of 9
Ed__Jobe
On your project properties, build tab, what is the platform target set to? Can you set it to x64?
Ed
Message 5 of 9
meck
No it will not let me set it to x64 only x86
Mike Eck
Using Inventor 2018
Message 6 of 9
Ed__Jobe
Not sure why you can't change it. Maybe its because you have references to 32 bit apps?
Ed
Message 7 of 9
meck
I figured it out and was able to get it to change to X64, but now I have errors everywhere. All of these to start with...
Imports Autodesk.Connectivity.WebServices
Imports Autodesk.Connectivity.WebServicesTools
Imports Autodesk.Connectivity.Explorer.ExtensibilityTools
Mike Eck
Using Inventor 2018
Message 8 of 9
meck
I got it to work!
I had to bump the framework up to 4.5 and then everything came back into focus.
I would never have been able to do this without your help!
Much appreciated!
Mike Eck
Using Inventor 2018
Message 9 of 9
Ed__Jobe
Glad you got it to work.
Ed
