cannot find embedded type 'autocad.iacadapplication'
mtwohig
Message 1 of 1
mtwohig
Hello all.
I am writing a Windows Service application using Visual Studio 2013 which is to start AutoCAD Mechanical 2016, make the app visible, do some stuff and issue a SendCommand. The command that I am sending works when I run it manually in the AutoCAD Mechanical 2016 UI.
The problem is that the SendCommand never fires.
My only relevant import is System.Runtime.InteropServices.
My code:
        'startup autocad
        Process.Start("C:\Program Files\Autodesk\AutoCAD 2016\acad.exe", "/p <<ACADMPP>> /product ACADM /language ""en-US""")
        'wait till the thing opens. 0 min 30 seconds maybe?
        System.Threading.Thread.Sleep(New TimeSpan(0, 0, 30))
        Dim acAppComObj As AutoCAD.AcadApplication = Nothing
        Const strProgId As String = "AutoCAD.Application.20.1"
        Try
            ' Get a running instance of AutoCAD
            acAppComObj = DirectCast(Marshal.GetActiveObject(strProgId), AutoCAD.AcadApplication) ' .AcadApplication)
        Catch ex As Exception
            ' If an instance of AutoCAD is not created then message and exit
            EventLog1.WriteEntry(String.Format("Instance of 'AutoCAD.Application' could not be attached.{0}{1}", vbCrLf, ex.Message))
            'Return False
            GoTo NOGOOD
        End Try
        'EventLog1.WriteEntry("Acad successfully attached.")
        acAppComObj.Visible = True
        'open up a new document - need to copy local for security reasons
        acAppComObj.Documents.Add(fi2.FullName)
        EventLog1.WriteEntry(String.Format("Opened doc: {0}", fi2.FullName))
        'wait for a few seconds
        System.Threading.Thread.Sleep(5000)
        ' Get the active document
        Dim acDocComObj As AutoCAD.AcadDocument
        Try
            acDocComObj = acAppComObj.ActiveDocument
            EventLog1.WriteEntry(String.Format("Could not open the active document.{0}{1}", vbCrLf, ex.Message))
            'Return False
            GoTo NOGOOD
        End Try
[... OTHER CODE THAT REFERENCES acAppComObj AND acDocComObj WORKS FINE]
        'plot pdf
        acDocComObj.SendCommand("-AUTOPLOTTOPDF ")
So the SendCommand never fires. Also, the application never becomes visible. Is it possible that the SendCommand will only fire in a visible app?
If I break on the acAppComObj.Visible = True line and step through it, .Visible always stays False. It does not error.
However, if I break on that same line and manually set it to True using an immediate command, This messagebox pops up:
cannot find the interop type that matches the embedded type 'autocad.iacadapplication'. are you missing an assembly reference?
So it is refernecing IAcadApplication rather than AcadApplication.
Is this because I am writing a Service app? How can I fix this?
Thanks!!
Replies (0)
